One shall not plug 220V in the secondary circuit of a 220-12V transformer.
Not a good idea. Like at all. Magic smoke coming from a cable is not that magic…
(The thin cable turned into a fuse, and may have save more than a small transformer…)
At least, I learned my lesson and made a circuit breaker protected plug to test further projects…
Sam was kind enough to give me a 3 x splashback when I went to the museum a few months ago. Finally built it and after correcting a few minor issues it still wasn’t working. I did some very diligent error checking to figure out -12V wasn’t getting to the opAmp.
Regret to inform I am Idiot and apparently mangled the new power cable on my test rig and, ironically, didn’t test it
Ugh I sent all day working up panels out of scrap plastic but when I started making hokes for components they shattered. The plastic is far too britle. If I wasn’t off my head with covid I’d be furious.
Yes, and I also sometimes ignore overlapping courtyards because there is so little space on the PCB bad practice, I know, but sometimes it can save me a bit of a headache
Nah, it’s not bad practice. It’s good practice to check and to decide whether it’s a real problem or not. Sometimes the courtyards are just bigger than they need to be.
When creating noyce PCBs, after reading messages for shorts and so, be reminded to check what you write on the PCB (like resistor values). Your future you is dumb and will follow exactly what’s written.
Inverting resistors caused:
a Schmitt trigger not to work (and the VCO not to oscillate)
a sine shaper not to shape (and the VCO not to produce a sine)
I use custom footprints that have both the reference and value shown, so I don’t have to “write on the PCB” so much. But they don’t always save me from scenarios like:
IIRC the oldest entry on the KiCad bug/feature request tracker is to specify a footprint as being non-polarised. That means you’ll be able to place a resistor either way round to avoid having to flip it and fudge about with the reference designators on the silkscreen. Eventually.
