Hey, I have started working on some 808 hihats. I simulated some stuff and the envelope is already working, I think
This is the envelope for the open hihat, which is affected by the closed one. I tried the same as in the hexinverter mutant hihat: adding a switch which determines if this happens and to what extent.
It was only a question of finding the right resistor
So:
red line:
no effect of the closed hat (the closed hat circuit is disconnected from the open hat, simulated)
green line:
small effect of closed hat (closed hat circuit connected via 300k), this should dampen the sound of the open hat somewhat when the closed hat is triggered
blue line:
big effect of closed hat (closed hat circuit connected via 10k), this should completely silent the open hat as soon as the closed hat is triggered
Maybe I need to changed some values, but the principle works
Now I need to decide if there is any point in replacing the so called swing-type-VCAs of the original 808 with “proper” (OTA-based) VCAs, as has been done in the hexinverter. What benefit would that give? Do the swing-type-VCAs not close completely or something like that?
Also, I want to filter the noise with a bandpass, but I have not yet found a good solution… I want something simple, no need for CV, just a simple knob should do, but I have not found a good filter design. I think I need to go with a gyrator based filter, because I would prefer not to use a dual gang pot and also no OTA…
But I had no success in designing it…
Here is an FFT of the noise:
It looks like it’s mostly around 4 to 10 kHz, so I want the filter to be in that range too.
When I use the standard tunable gyrator bandpass from Elliott Sound Products I get this:
I would like to shift that a bit higher! But when I reduce C4 or R1, the overall gain(?) drops:
If I lower C1, the bandwidth gets very high and I think I don’t want that:
So, I am clearly missing something, but I don’t really know what! Any ideas?
