Hi Gang,
hope everyone is doing alright in these crazy times
I’ve built Sam’s 3340 VCO strip board 2 separate times, and both times I have problems with the PWM detuning the oscillator. I’ve even breadboard it and I have the same issue. All of the features work fine, I can calibrate it to track 1v/OCT, but if I touch the PWM pot or the PW pot it will slightly detune the frequency of the oscillator. I would consider myself an intermediate to semi-advanced DIY’er, I’ve quadruple checked my work and it all checks out. Anyone else have this issue ? I’m using the AS3340 chip FYI, and I have even swapped out multiple IC’s to make sure I didn’t have a dud chip but the results were all the same. Thanks and much love !!!
It’s a known issue with the 3340s, see e.g. this subthread:
I just recently found this "To improve stability of VCO during PWM excursion, simple solution can be used: " - Is this related to OPs issue above?
ah this basically uses a diode to reduce voltage swing.
Interesting! Might give it a go - I had this issue pretty bad on mine. I did a few other tricks to tame it a bit which I posted here:
See also this
which is the build guide for the Thomas Henry VCO Maximus. It’s a different circuit than Sam’s but might provide some ideas:
As usual Thomas Henry did design this project for 15V, alas, time
has shown that this circuit could not be used with 12V w/o a lot of
changes. Especially the PWM did have an impact on the overall
pitch. I am very thankfull that ‘chrissugar’ from Romania did a lot of
valuable work and tests to tackle the PWM/pitch-issue. I amended
this documentation accordingly.
Evidently one of the modifications referred to is to power the 3340 with +11V from a TL431.
Also here:
https://modularsynthesis.com/mrmrshoes/maximus/maximus.htm
The PWM control did affect the frequency as has been noted in various forums. I changed the 10R power series resistors to ferrite beads and added a -5V regulator which stabilized the frequency when changing the pulse width.
(Not clear where that regulator fits in.)
You can use a -5V regulator for the negative supply, instead of relying on the built-in zener.
(not getting the feeling that these mods are very scientific, though
