While trying to calibrate/tune my #1222 VCO I used my oscilloscope to measure the frequency as I don’t have a good enough ear for tuning, and I got some weird readings from the scope. The frequency reading would sometimes jump up when it should be going down.
After some poking around, I noticed that there was some high frequency oscillation on the falling edge of the pulse output.
The lower the VCO frequency, the more ringing/oscillation on the falling edge, and it can get quite bad.
This starts happening when the VCO frequency falls below about 200Hz and because this unwanted oscillation is quite high frequency (on the order of 15kHz) it is not heard and it doesn’t show on an oscilloscope when the time base is set to see at least one full cycle of the oscillator.
The ringing is such a high frequency that it get slew limited by the opamp on the #1222’s output, but it is still clearly present.
I only have AS3340s so I haven’t experienced this myself with the CEM3340, but after observing it, I found this web site which mentions it also happening with the CEM3340.
I tried connecting an additional 0.1µF decoupling capacitor directly between the VEE and GND pins of the AS3340 as I thought the one in the #1222 VCO might not do its job properly because it is on the wrong side of the R6 resistor, but it did not make any noticeable difference.
So just a heads up, this is probably not a big issue if the output of the VCO is just connected to the input of a filter, but if it used as a clock for a responsive enough circuit (e.g. a fast clock divider) it might have unexpected results.
Has anyone else seen this issue?
Between this and the frequency drift caused by the PWM input, it seems like the pulse output of the AS3340 and CEM3340 should not be used and a pulse signal should be derived from the triangle output using a comparator instead.
