Hey everybody. I am starting to get more time again and made a pretty much finalized PCB for my Witches Brew Joystick Stackable v1.3. It has been so going because a bathroom renovation so it has been slow going.
I know a few where interested in a product like this. I was wondering if I could gauge the interest in the use of this board. I am planning on releasing the gerber files and maybe shipping some PCBS if people are interested that don’t have a lot of time. I hope you are all doing well. It was a real learning experience with doing the artwork and prototyping. But really feels like it paid off with the finalized version.
Features
•Clearly Labeled Sections on PCB/Schematic and low parts count for beginners.
•X and Y Axis CV for Joystick
•Panel Mounted Offset/Range Knobs X/Y Axis
•Offset Postive/Negative Voltage LED Indication
•Passive Attenuator Output
Looks good, I actually have a joystick coming one of these days though I’m not in a hurry to build anything with it. If Gerbers are available I’ll probably add it in to one of my board orders. Thanks.
The bottom image (lighter blue) is the back, solder side, right ?
The pads are covered with silkscreen, I hope the manufacturer will clip it to the solder mask…
Yeah the lighter blue one is the backside (lighter because of a ground plane). Rev 1.2 version I ordered they exposed the copper pad under the solder mask when I ordered from JLC PCB. So I am pretty sure even if silkscreen overlays through holes or copper pads. It is standard practice to ignore silkscreen covering copper pads.
@Circulartonic has not visited here since July 2021, and the project page seems not to have been updated since about then.
Those interested in a Kosmo format joystick module (or make your own mods for Eurorack or other format) may want to check out AO joystick Kosmo module.
