Planning on Ordering my first PCB for one of my first completed projects. Does anyone have any suggestions before I pull the trigger? I am planning it too either be panel mounted jacks in a KOSMO type panel or in its own enclosure. I have a power header expansion board So you can stack them if you wanted a dual joystick Box.
This looks great! And I want. For kosmo version would you put the joysticks right on the panel or a port for a wired controller of sorts?
Looks like a nice clean pcb. I like the art. The only things i noticed are the traces being kinda small, probably fine. And also the 4148’s at the power header—I could be wrong and there are smart people here who could say for sure —but isn’t there a better choice? I know some of the guys like @analogoutput use 1N5817. Which is what I’m switching to use.
Yes a front panel header with a breakout board is possible. I recently found someone modded their DOEPER A174 INTO a remote Joystick 5 pin Din socket. Which shouldn’t be that hard too do. Also when I was using mine my hand was getting pretty tired after a while lol.
The traces are 10mil Width Which should be ok for the circuit with the amount of current it takes. If anyone knows what the standard Size traces that LMNC/other manufacturers uses on their modules. That would help.
Sounds like you’re cargo culting after a cargo cultist.
But yeah… Schottky diodes are what Matthew Skala uses and I figure he’s a good role model — your schematic shows Schottky symbols but 1n4148s are not Schottkys, with 0.65V forward voltage vs. 0.45 for the 1n5817s (and 0.2V for whatever Skala’s using, hmm, never looked into that.)
Then again, my most recent Tayda order included a bag of resettable polyfuses…
Ah, okay… Skala seems to be using 1n5818s, rated for 30V vs 20V for the 1n5817, and forward voltage at 1 amp of 0.55V vs 0.45V for 1n5817. He says “In normal operation they drop a small voltage (0.2V for the Schottky rectifiers I like to use)” but that presumably is at typical module current.
While I was on Skala’s site I decided to download one of his PCB layouts and take a look at it: his power traces are 35 mil and others are 20 mil.
Edit to add:
Music Thing Modular (Mikrophonie): 32 and 24 mil.
Mutable Instruments (Braids): 16 and 10 mil.
You need a quite a few amps to set fire to 35 mil traces, and if your TL07xs consume that much current the traces are probably not your only problem
(6-8 mils aren’t uncommon for small signal work; if you need more for the supply traces depends mostly on trace length and number of things at the other end of the trace. Reasonably short traces with no more than 100-200 mA or so will probably not require extra attention. Also, cheap PCB fabs may not handle traces below 8 mils well, so that’s another reason to keep it a bit bigger.)
You’re using component designators everywhere, but no component values. This is a design choice, but having component values on the board saves you a lot of time when building. Also, designators are mostly useful when troubleshooting, but as designed you cover a lot of them with the components, which renders them somewhat useless for that purpose.
And do you really need designators for the holes?
I’d make the tiny “—red—” bigger – it’s more important that + and − is clear than it is to spell out that it’s a power connector (the socket and clear + and − marks kind of implies that anyway).
The R7 and R23 connectors are slightly misaligned horizontally. Intentional?
(schematics) The gain for a non-inverting opamp is 1+Rf/Rg, not Rf/Rg (so 1+4.7k/2.2k = 3.1× in your case). (Also, you cannot really overcome a (relatively) fixed forward voltage by multiplying with something; you’ll reach the threshold 3× sooner, but you don’t bypass it completely.)
Is there a way in KiCad to tell it “put value on the silkscreen layer for all components”? I know how to do it for one component at a time but not how to make it the default.
Also that comment on positioning is something I wanted to mention to @lookmumnocomputer. On the one module of his I’ve built (the 2399) most of the components have both designation and value shown inside the footprint, making it about impossible to figure out what is what on the assembled board.
Thanks for the tips. It will help make the design overall better and help me gain knowledge.
The gain for the LED indication circuit is referenced to the final output Voltage.
So it is only amplifying the output signal too the point where if there is any type voltage being outputted the led can pick up of signal. So wouldn’t work at displaying a linear led brightness for a indicator?
It seems too work fine, but I should change the values a bit the Point it detects signal at below 500mV.
Is there a better way too do the same thing?
My point was that since you need to get above a certain voltage before the LED starts doing anything at all, and that voltage is quite high, multiplication won’t fix things on its own; a small voltage will still be below the threshold if you multiply it by 3. But I’m nitpicking on the text in the schematics, not the functionality – if it’s useful in testing, go for it
To illustrate what I mean, here are the forward voltage and intensity curves for a random red standard LED; there’s nothing linear here, and you need to get above some point between 1.5 and 2.0 V (after multiplication) to get anything to happen:
I am very interested in this pcb, what joystick did you use in the panel ? I really like the simple layout design and looking at it , it looks like a pull that trigger go project
This is the joystick I used. It doesn’t have a spring. So it doesn’t spring back too center.Joystick
I am working on V1.2 that is even easier too read with the values on the board and a more optimized wire routing. When I started this PCB I wanted it too be as beginner friendly as it can be. Minimal parts, Sections labeled.
I am planning on releasing the files for free. So anyone can order them If they are interested in DIYing them. I mainly did this for practice. I am still pretty much amateur at designing. If I revisit the Circuit again in later revisions and do more testing and modifying the design with more features. I might consider releasing revisions as a product. Since its simple design too understand and learn from with common parts and with people order 3-5 pcbs. They could give them away too people that are starting to get into DIY Synthesizers.
You are right about this. Did some further testing the method. I am using only only displays down too 500mV. Still works well for a display. But If I want too display it more accurately. I would have too think of another method. Like a Voltage -> current control method.
I also noticed LMNC Used Voltage Follower For his Dual VCA Design with a bipolar Led. Which I was using until I came too the problem of having 2 LEDS with Voltage a Different Forward voltage. That is why I Changed my Design A Non-Inverting Amplifier too overcome that problem.
