I finally had a chance to play a lot more on “Wanda” and it’s so dang cool how the filter grr mixed with the dual buffered multiple can really bring out some juice, then mixed with the performance filter before heading out O_O
ahhhh that’s the sauce, these modules are so worth it!
I haven’t designed another module for it yet, I’ve got a few schematics that are nearly finished, but nothing really ready to make into a module yet.
Figured I’d try out the kosmo modules and try to avoid doing the same things that way there’s variety
Anyway, the main reason I started this thread was because of my inability to keep focus when scrolling walls of text with pictures when it’s a conversation full of people, I literally can’t do it.
The secondary reason was because the modules I want to build are kosmo format, it seemed that the best place to put them was here.
I’m a full time parent and engineer, so I don’t often get to socialize and so trying to mix in to the regular areas where people are trying to hold an active conversation seemed a bad idea since I can’t keep up with conversations as it is.
Some people I double text in an hour, some people I’m only just remembering during this post, after weeks… whoops… So my apologies that I can’t keep up regular conversation… I’m doing my best.
As to any issues with the kosmo modules to share? None at all, they’ve all worked beautifully! …outside a few things that were my own fault… XD
I also made a few alterations in materials due to missing components, with a few modules…
Like with the dual buffered multiple, I used a 1.5m ohm instead of 10m ohm, dunno if it makes a difference in performance because I don’t have a 10m ohm to use, so I used the highest value I had, works a charm from what I can see. Used it for gate and CV without issues specifically.
But anyway, here’s the pictures of the patch I played earlier if you guys want to see.
