I would like to have a place where can I and other people post some circuit ideas/stripboard layouts that are unverified but actually could work.
I would really like to know what this circuit exatly is and how it works. Can someone more skilled tell me?
Thanks for your replies!
I built the old design of it, which unfortunately didn’t work, tomorrow I will adapt the changes to this new design. I will then report whether the changes have led to success!
What VCOs are you using with the ring mod. Mine 3340 triangle didnt work with this circuit, but saw and pulse did work.
I connected it to my Behringer neutron
Do you know the output voltage?
I think it’s 10v, but I’m not quite sure, I’ll measure tomorrow
Did you try all the waveshapes?
…I’m not sure if I did that anymore, I’ll check it again tomorrow before I make a change
We actually do have a thread for that, The UNVERIFIED Lounge
I think if you want a “real” ring modulator then you should build the YARM+
Yeah, I know. But I wanted this thread to be a place where can i share circuit ideas and learn more about electronics. But thanks for the reply!
Maybe it will be good to add “Not verified” on the pic, if people find it without the title and the topic
So I want to announce again that my ring modulator works with the new design, it only works with SQUARE. Musically, I think the modulation is usable
Technically, it works with any signal [1], but the behaviour is somewhat undefined for certain voltage ranges so it might not be that useful. Unless you want aggressive distortion [2], that is
[1] Even outside the supply rails, as long as you don’t fry the protection diodes.
[2] CD4011UBE has softer clipping, so might even be useful.
@peppy verified it! So it should be ok.
