As I cannot find suitable transformers to build a classic transformers/diodes ring modulator, I acquired several other components that can be used to build circuits that result in a similar sounding effect (MC1496, etc).
As usual, I am working my way from the most simple to the more complex designs starting from a simple design that comes from the Korg MS-20 service manual which uses the CD4011 (ARP Odyssey also used the CD4011 to a similar effect).
My build seems correct, although I cannot seem to get the module to work with all the different sources that I tried at the inputs. It works with simple CD40106 oscillators and all kinds of LFOs, but not with the pulse VCO output from my Crave. After thinking about it for a while, I concluded this behaviour must be due to a need for DC coupled inputs. The oscillators and LFOs are all DC coupled, but I suspect that the Crave VCO outputs are not.
If anyone cares to weight in and confirm this, I will just plug the module back to the case and move on to the next “ring” modulator project!
