Was finally able to get some time for myself this weekend since I have been on the front lines of this Covid stuff and tried to build my first super simple VCO (pictures below). The soldering part still needs some training but did I get it right?
And now I have an issue: I don’t know the best way to solder the cables. Do I have to cut the plastic around it and solder just the wires. If so what’s the best way to cut it?
You soldered to the wrong side of the veroboard. The components should be on the other side.
However if you just solder the current side the components are on then it should work fine.
Easy mistake to make, especially given how the diagram looks. I just imagine the strips are there for reference, and build from the non strip side in the same way as i would if the strips were on top.
I definitely sound a caution on that. As a child I occasionally used to strip hookup wire on my top front teeth. This damaged the enamel and I had to replace them with crowns before I was thirty. Always take the time to find a suitable tool, never use your teeth, however tempting.
if you can’t find strippers and don’t want to wreck your teeth , the cutters in your picture will work . it just takes a bit of practice and a lite touch . very lightly pinch the wire [plastic coating] and pull this will strip the plastic off. https://youtu.be/oVfA54MJUhw this is a short clip of how its done.
Hey there! I found another simple VCO using only opamps a transisotr and some passive componants! I don’t know if it sounds well so if someone could help me to figure out if it is a well oscilator I’d be thenkful ^^ (cuz yeah as3340 is kinda expensive haha)
Here’s the schem: (don’t care about C_IN and C_OUT)
