My Simple VCO PCB... First Test
So my PCB’s arrived for my simple VCO a coupe of weeks ago, I have been waiting on some 620ohm resistors that turned up yesterday. This morning I decided to test, this is my firsy AUDIO test of any module…
1st problem was that the master tuning knob made no difference, apart from emitting smoke at one end of the track.
2nd was the triangle was not outputting…
Anyone spot my two glaringly obvious mistakes??
I have it working now on the SAW correctly. Just need to fix both issues properly tonight… No major work. Killed £1.50’s worth of component.
But with that done I have something SOLID to test everything else with, and some confidence.
with just a glance I think there is a connection that is not good
VTO is triangle out, so checks out.
This would probably qualify for this thread.
Also the pot in the top left looks weird. Pin 2 and 3 are reversed? This could explain the smoke, if you turn it to one end you make a short!
Good catch! (totally missed that potentiometer at first)
And you don’t have to turn it that far to damage the potentiometer itself; if you’re using one of those tiny 9mm 100k potentiometers, they’re rated for a paltry 0.05 W which corresponds to max sqrt(0.05/100k) = 0.7 mA through the pot for a 100k pot, which you’ll reach at around 45 degrees from the end position.
Yep, the tuning pot is incorrect.
The triangle has no output, and it’s connected to TN.
These must have crept in right at the last second… 2 mins fix when I get home.
And yes I did think of that thread as the two mistakes jumped off the page.
All fixed and working as expected :slight_smile:
I was a little downhearted when I first tried it this morning, but once I had spotted the two issues in the schematic I was relived and confident.
The difference in amplitude between the SAW and the TRI is quite noticeable but not a great problem for what is really just a test module.
Onward and Upward…
How good of YOU to spot those problems …
This was a can you spot the issues I had identified myself…
I had already worked it out but thought it may be of interest for someone else…
“”"“Anyone spot my two glaringly obvious mistakes??”"""
you mean that you opened a topic just to see if others found errors on your schem of your module which did not work
really ?
Ah, misunderstood that. Waste of time in my opinion. If everybody starts showing random soldering mistakes or copied some part of a schematic incorrectly, that is not something other people will likely learn something from other than that it is wise to pay attention to what you are doing.
CHEERS is a thank you, I thank everyone lots.
I thought it would be an interesting little challenge for people to spot some OBVIOUS mistakes that creep into designs.
I said in the first post that I had identified the issues and was able to fix them, so it was just a challenge out of interest if someone could spot those silly errors that had crept in.
No worries. We are used to people asking questions about problems they have not solved yet. And there are plenty because quite a few people are just starting in electronics and synthesis.
it was solved within minutes when i reloaded the schematic., but I THOUGHT it may be fun to have a laugh at my silly mistakes as per the Dumbass thread.
But seems not.
there are a lot of people who have problems with their constructions, so actually it was a waste of my time
maybe with the title “Find errors in my schematic challenge” it would be better spent I think
Simple misunderstandings can happen yall. Going forward, i think all would agree a similar post should frame the discussion around it being a challenge. In hindsight it would make no sense for someone who was requesting help to know the exact number of mistakes made. The context is usually to help address problems, so if we are not doing that lets just make sure to clarify. :slight_smile:
Thought that was pretty clear, but then again the people objecting are AFAIK non native English speakers so maybe not so clear to them. Anyway, I enjoyed the thread.
At AO :slight_smile:
what was supposed to be a fun item has caused unrest :frowning:
