Topic 352 about this project. I know. I’m a newbie, and yes, I only discovered now that so many people start off with this project, and are having troubles.
I’m using the SS9018 transistor, so I can work with a 9 volt battery.
This is what I got: https://youtu.be/fUQr2TAah-U
I double checked the sheme, and should be correct. Should I use other resistors then the mentioned 1k & 100k?
