Simple Twin-T Kick Drum
That’s how I’ve ususally done it…but I learned more about power nets a board or two back and was able to just use PWR_FLAG’s to identify them so it automatically hooked that up behind the scenes. Not sure why it’s not doing that on this one. But I was getting pretty tired last night and didn’t try to think it though - was just trying to get all the components down :smiley:
I don’t fully understand how that part of the circuit works either. It comes from the dogsnakes noisedrum (which I really like as a hi-hat) and it works…I’m just not clear on why/how.
Good idea…I’ll try and do that a little later.
I think this is the noise generator as discussed elsewhere in this thread. It’s advisable to cut that unused collector leg very short so as to eliminate unwanted RF interference.
the transistor with no connection at all on collector ?
i think it’s the master piece for create the white noise
I guess now that you have +5V and +12V power nets, kicad just chooses one… by some arcane algorithm…
Did you have both in your previous design(s) where it worked ?
I never trust software… I know why, after all, I’m a software developer :slight_smile:
Yeah, The ones I’ve used that method in before didn’t have +5. But it didn’t pick up the -12 either.
But…I’ve also only used it with TL074’s and this one is a TL072 so it could be a difference in how the part is defined in kicad as well.
I guess it knows which pin of the IC should be positive and which negative, but by no means can it know which voltage.
I never designed a symbol in kicad, so maybe I’m wrong… what attributes can you set on power pins ?
In the video, his module (Twin T kick) have an Attack select switch, it’s not in the schematic and i really don’t understand his explaination about it.
Some one can help me plz ? what’s he saying ?
He says these diodes are connected to the switch to provide two attack responses but yeah it doesn’t show how…but I imagine the switch would break the path going thru both diodes
As far as I can see it’s just switching between two cap values to give you different lengths of decay…like sso pitch ranges. Or did I miss something?
Edit: yeah I missed that. Im off to sleep
yes i think it’s between the 2 diodes and GND like you said, thx
Yeah, simple switch connecting the diodes to ground or just to leave them hanging in the air.
I must say, I got surprised find a thread about this in here :smiley:
Also, “lovely Finnish accent”. What :smiley:
Maybe I’ll make more videos like this, with better explanations.
Tervetuloa! :smiley: :smiley: :smiley:
thanks a lot for explain @Krakenpine
what name i put for the “Original schematic by …” in my stripboard layout version plz ?
I would also add the Attack switch.
I build it, here my Twin T Kick Drum stripboard version verified
Hi, I made the Twin-T kick Drum on a stripboard, but I have a problem with the trigger input, it only works when I send a negative gate, the craziest thing is that it worked normally last night, I double checked and reflowed all my connections (from the krakenpine schematic and the stripboard layout), it’s driving me crazy and having only a first price multimeter at my disposal I don’t know what to do to debug it since I have no point of comparison.
Do you have any leads, tips or values that I’m supposed to have on certain components?
For example, what voltage am I supposed to have between the 0v line and the different legs of the OP-Amp?
Also I noticed that I have a few millivolts between R1 and GND but it seems normal to me from the schematic
Thank you, for your time :pray:
Hi to you, sorry I suck in theory (other here could help you better), I just made a stripboard from the diagram and everything worked on the first try. Check your circuit again, there is bound to be an error somewhere . Maybe show us pictures.
I’m sure that the problem is on my side since it worked briefly, I’m changing all the capacitors, since I can’t test them with a multimeter, here are some pictures.
The full view :
Zoom
Zoom
Part A
Part B
Part C
PS :
For part B the two resitors solder to each other are just 1k and 2k put together to get a 3k resistor
For the part C i juste moove part to the center to have some space for when i will do the led driver (the rectangle on the right)
The two rectangles with a hole on the left are for the monting brackets.
The big horizontal line is GND, +12 on top, -12 on the botom and vertical black lines are the paths wihch i cut
I’m re-building it from the begining, it’s not like it’s a lot of part, and i can re-use jack, pot and the op-amp, i think it will be easier this way.
Ah ah, i’ve got the same probleme with the new build :grinning: so i think it’s come from the part i change I will post the modified layout.
