Quick/silly question about relays:
Can you use a relay with a 5v coil to switch a 9v or 12v signal? say you wanted to use lower volt arduino logic voltage to power the relay coils for switches carrying synth level signals
Or is it better to use your low voltage on a relay driver transistor that opens up the bigger voltage to the coil
Data sheets show minimum trigger voltage and “nominal voltage”
Bit confused
