Not entirely a relay question but relayted to my situation. Here is the circuit im using to open a relay on a gate signal. A “high” gate on the base of the transistor allows the 12v to make its way to ground, switching the relay. The diode is to protect the transistor
My question is what if you want to do the reverse, that is, the relay is normally in a powered state and a ‘high’ gate interrupts power through the coil?
Here is more detailed to where I’m stuck. The relay controls whether the mixer is in stereo mode or mono mode. So I’m already using both the NO and NC pins
With no gate the left and right carry on to the outputs. When gate applied they get mixed together to a mono signal.
I want to add a switch that reverses the behavior
I suppose I could add another relay after the switch with the opposite pin out on the NC/NO, I just figured there had to be a more elegant way to invert a gate
You may probably leave out the R (R2) to GND. Just make sure that the transistor can switch the amount of current the relay needs (check the specs of the transistor).
That’s funny, I was absolutely bombarding it with bipolar lfo on my breadboard for a couple hours the other day to see if I was going to burn out the relay, didn’t think about the transistor! that is probably a good call!
Hi all,
I’m not sure if this is the appropriate place to ask this, but I have been getting inspired by LMNC’s relay videos and considering experimenting with them myself - unfortunately I have no idea what relays to buy, or which ones he is using. I’d like to be able to switch modular audio/CV level signals using an Arduino (using 5 volt or even 3.3 volt logic levels), with as little distortion as possible. I want to be able to switch destinations, not just on/off (I think that would be double pole?). I don’t mind much if there are clicks when switching, as long as the signal is fairly clean when switched. Does anyone have a good product recommendation from Mouser, Tayda, or Jameco?
These are some of the products I’m thinking might be in the ballpark:
The 1A is plenttty big enough. I got some of the micro sized blue colored 2poles from tayda, 5v and 9v—they are nearly silent, which is good or bad depending on what you want. The black ones from tayda are bigger and louder. The voltage listed is the voltage required to trigger/switch the relay
