If you are the careful king of guy, which always plugs cables in the right way, just use simple double-row pin headers, like these : https://www.taydaelectronics.com/2x40-pin-2-54-mm-double-row-pin-header-strip.html
Just buy them where you buy your other components, everybody carries them, even if they are a few cents more you will save on shipping.
Just cut them to the length you want, that’s easy, they are designed for that.
Amazing, I’ll definitely go with the box-headers as I wouldn’t want to mess up the whole thing by pluging it the wrong way around, thank you so much for your advices, lets start building !
I have a single last concern concerning the FC power, I know I need a 12V AC - AC Wallwart, but I don’t know exactly which one to take, is there a specific one needed or any 12V AC will do ?
I know I ask a lot of questions and I’m sorry for that, but I really want it to work !
Hello again, I spent all evening looking for an afordable 1000mA 12VAC wallwart but I can’t find one for under 30 euros to be shipped in or to France, would any of you have any good deals for a cheap one ?
Sorry for bothering
[Edit] : would this one work on the FC power ? I’m not sure for the tip would fit in the FC power’s mount.
Well turns out they don’t ship it to where I live
I’m so sorry for spamming but would this one work ?
I wouldn’t want to buy the wrong one given the cost
Hello !
I am back with my noob questions, I just finished soldering all the parts on my stripboard, and I have a couple of concerns :
- How do you know what way to put the CEM 3340 (ended up using an AS 3340 but hey) and the TLO72 in the IC sockets ?
- Do I connect the ground of the jack sockets together and then connect one of the grounds to the stripboard ? Or connect all the grounds onto the single spot in the stripboard ?
Thank you for your help !
There’s a notch that lines up with the image on the ICs. If you’re not sure you got it right, post a picture before you power it on. You can do either for the jacks.
