Power supply issue?
Hi there!
I’ve been building a VCO bank composed of 5 Thomas Henry VCO-01, and a classic power supply unit (220-12V AC + LM7812 + LM7912, big caps, etc).
I have a strange issue with, from what I suspect, the PSU.
When one VCO is plugged on the PSU rail, there is no problem, it always switches on correctly. When two or more are plugged, I get some wrong starts, the oscillation does not occur (I just get a flat minus 8V on the outputs). So I switch off and on, and sometimes, it works on, sometimes not. I kinda have the feeling of rolling a dice here.
I changed the two tension regulators, but nothing really changes.
All the VCOs behave the same: they all work, or the all don’t.
Could this be an inrush current issue?
Analog output did a nice job figuring out that the positive regulator needs to be clamped with a schottky diode otherwise can be pulled negative and fail to start
That’s was exactly the solution!
Strange fact is I bought 1N5817 and I am pretty sure I saw the AO video in the past. And totally forgot about it.
I guess I was a bit panicked and tired ^^
Thank you!
That’s assigning me credit I’m not due. @savt22 pointed out a mention of this solution from modwiggler; all I did was to set out to check if it violated any best practices and discovered it was recommended in a more authoritative source.
My apologies .
Your video explaining the issue is an excellent resource
I haven’t extensively tested my new power supply yet but so far it starts up every time with the clamping diode mod
You RTFM for us, poor peasants, and brought it in an easily understandable package.
Huge thanks for that.
