Excited, and figured I would post about it.
I decided to look around for a couple ADSR’s, a couple VCA’s and a couple Power Options (for some future projects I have in mind - small Eurorack cases
Here is what I ended up ordering today!
MKS-006 : Exponential VCA
From NCS: “Exponential-response VCA built out of TO-92 discrete transistors (20 of them per channel!). The circuit is more or less that of an LM13700 operational transconductance amplifier chip, build out of single transistors for art’s sake. It’s not exactly hi-fi, but it imparts a warm and sweet crackling distortion that I rather like. It also provides a fair bit of output power and could be used for tasks like driving headphones or small speakers directly”
MFOS Dual Log/Lin VCA [PCB Design by Nickajeglin on github]
From Ray Wilson:
- Log and Linear Response to Control Voltage
- DC Coupling Throughout
- Excellent for Ring Modulation Effects
- Power Supply Range +/-9V up to +/-15V
VCAs are essential to your synthesizer. They provide ring modulation effects, stereo panning, delayed vibrato, not to mention the normal envelope shaping of your sounds. This VCA works nicely with 10V PP (+/-5V) signal levels.
AI003 ADSR by AI Synthesis [PCB Design by Nicholas Guest]
From AI Synthesis: " The Looping ADSR Envelope Generator is an ADSR Envelope Generator with the ability to also function as a variable wave LFO. This module can be used to feed control voltage to a filter or vca to modulate, for instance the volume of an sound source, or the cutoff of a filter."
Simple 555 ADSR (based on “The Fastest Envelope in the West”) [PCB Design by eViper1]
This is a pretty well known ADSR that has been around for quite some time.
MMI Modular USB Power Distribution Board [Open-Source - Based on Tom Whitwell’s “Stupid USB Power”
This small Distribution board takes 5v USB Power and steps up to 12v +/- w/ 5v Rail @ 412mA 12v +/- and 5v dependent on USB Power.
Dintree D112 Eurorack Power Supply (Gerbers available on the site)
From Dintree: " The D112 Power Supply is a high quality Eurorack power supply designed for a single row of modules. It can supply 625mA at +12V and 625mA at -12V using a DC-DC dual-output module. Additionally it provides +5V at 500mA using a DC-DC converter on the +5V line as well. A single +12V supply powers the unit.
- +12V and -12V at 625mA each
- +5V at 500mA
- single +12V power input required (1-2A depending on load)
- high-efficiency switching design
- 12 power bus outputs
- power bus indicator LEDs
Thanks @Caustic for the guide on your DIY Panel thread, it helped me order from JLCPCB
