Ok…video tomorrow. Got to talking to a friend and “lost” my evening.
But…did do something else today.
Had to go to the store for some stuff. Took a look at inkjet printers while I was there. I know…I hate inkjets. But…so many people seem to be loving them for making PCB negatives so I thought I’d take a look. Most were out of stock…what was left was actually the cheapest option. A Canon MG2522 for $35…quite a few of them actually. I’ve had good luck with canon inkjets over the years. I loved the BJ-100 when it originally came out and until just a year or two ago I still had a BJ-200e that I still used because it was rock solid reliable and ink was dirt cheap for it. But given the difficulty of using a parallel port printer anymore I finally pitched it after stripping it for parts a few years back (I was hoping it would have suitable rods for me to build a 3D printer around…it didn’t) I also have a Pro9000 my wife won in a photography contest about 12 years ago…they don’t even make drivers for modern versions anymore but windows will still use vista drivers so I can still print to it. Only problem is ink for it is crazy expensive and is pretty much dry each time I go to use it. I also have an old Canon all in one (that uses the same inks as the Pro9000) but I only use it as a scanner since it has a nice sheet feeder.
Anyway. Point is the $35 Canon followed me home.
But I’m not impressed. Results don’t seem to be as good as my laser
I tried it on a transparency first - not expecting good results. And got what I expected. It looked ok when it came out. But close inspection showed it wasn’t very opaque - and…the ink never dried. I did see an article about someone who uses this to their advantage by sprinking toner powder over it and then using heat to set the powder…but…that just sounds crazy messy and like just laser printing is a better approach.
Next I tried my vellums. It worked…but even with the settings cranked as high as they could go it’s just not as dark as my laser:
The inkjet transparency is the lower right corner…you can see how it smeared even 30 minutes after printing.
So here’s a better comparison without that but with both vellums on laser and inkjet…and laser on two transparency options:
So…the two laser transparencies look like they have the highest contrast. The laser Staedtler vellum looks like it’s denser than the laser strathmore (the strathmore is more UV transparent than the Staedtler though) Both inket vellum prints look less dark…but the staedtler looks better than the strathmore.
The “new” to me Koala laser transparency looks better than the generic transparency I was using before. It’s also thicker and didn’t seem to warp like the cheaper stuff did. So I may have to give tahat a try.
So I may have to try the Koala transparency with the laser…and my thought of trying the staedtler for my negative but the strathmore for my diffusion on the light might be the best bet.
But…I also got a string of UV LED’s so I’m going to build an exposure grid tomorrow which should let me get shorter more even exposures without the diffusion. So maybe that along with the Koala or Satedtler will give me the best results.
Though…I need to finish building these two Yusynth boards I did etch already. I’m waiting on the IC’s for one though so no rush there…the other I didn’t have the right trimmers but new ones will be here tomorrow so that will probably get built at least!
So it will be stripped by morning and I’ll drill it so I can try to build it up. A little worried about some of the traces just due to how the art came out…but should be able to make it work.
