Ok. Time to get a little serious and stop just playing around. I’m going to try and be a little more careful and control some variables a bit better.
I’m past the bad part of the roll of UV film so that problem solves itself. I was more careful cutting a piece off and this time I put the board in water and put the film on the the board under water. This did seem to help a bit. I was able to slide it around and work out any air bubbles quite nicely. I think I got the most evenly consistently covered board yet. I gave it 4 passes through the laminator - 2 on each side.
I stepped up my exposing game. One of my nicer tripods (inherited from my wife) has a big 3/8-16 threaded screw on the bottom of the center post. So I fired up Fusion 360 and designed a little adapter that would thread onto that (since I didn’t have any 3/8-16 nuts on hand and didn’t want to deal with going to the store just for one stinking nut) and printed it out. The design took about 5 minutes and the print about 35. Man I love having a 3D printer
The threads on the bottom of the tripod shaft:
My quick and dirty adapter:
F360 has a built in tool for making threads now…the hole doesn’t even have to be the right size…just close. So easy. Even on a low quality setting for my printer they printed out well enough to screw onto the threads just fine:
Then grabbed a few bolts washers and nuts…they aren’t the idea size…but 10-24 is what I had on hand and they’ll do:
Extend one section of legs on the tripod and position my UV lamp 12" above the top of my contact printing frame…seems like it should give full and even enough coverage:
So…now I have a way to get consistent exposure!
Let’s do an exposure test with that nicely coated board. I found a nice set of exposure tests here: https://ezcontents.org/pcb-fabrication-part-1-dry-film
Printed them out on my vellum and decided to see how a single piece of vellum would do. There are 10 swatches on the exposure test so I did 10 - 30 second exposures. I started with a piece of cardboard covering all but one then pulled it back to expose the next set of tests every 30 seconds…with a timer. Then developed it.
This was where I made another mistake. I forgot to remove the protective film off the resist before developing it. After 5 minutes in the developer it STILL wasn’t developing and I was starting to really wonder why. Then I noticed the film separating from the board and remembered…oops. I ripped part of the resist removing the film. I’m not sure if that’s because the developer had softened it or if my 4 passes through the laminator weren’t sufficient with the water I used to position the resist. Bummer…that makes this test a bit less helpful. But…still good for judging exposure through one sheet of vellum.
And here it is:
Ok, so right off the bat - 30 seconds won’t cut it with vellum. And the entire second half is no good with the areas that were masked off showing quite a lot of leakage. Let’s take a closer look:
Ok. So about the same. 2 looks a bit underdeveloped, and 5 looks like it’s showing a bit of leakage. So let’s zoom in on 3 and 4 (or 1:30 and 2:00):
These both look pretty darn good. I inspected them under my microscope…and actually took a BUNCH of close up photos I planned to share…but…the scope saved them all with the same timestamp and non-consecutive file numbers. So it’s really hard to tell which is which
but I’m pretty sure this is the center of row 3:
That looks almost perfect. But…if you look at the top of row 3 in the big picture you’ll see some of the tiny text up there isn’t quite right. Here’s a look at the tops of #3 and #4:
So the text at the top of #3 seems slightly under exposed…but the text on #4 looks a little overexposed as its’ starting to block up.
Same with the second set of lines…on #3 they’re well separated and clearly defined…but on #4 we’re starting to get some bleed between them.
So for one sheet of vellum I’m thinking an exposure of 1:45 is looking like it may be the sweet spot. Or at least pretty close to it. And it looks like 1 layer of vellum will resolve 10mil traces.
Note - I think this test pattern actually came from here: https://github.com/sleemanj/pcb-test-pattern
And was reworked based on the text in the blog post where I found it. And I think he shrank it down (inadvertently or not I can’t say) when processing it as it looks smaller to me. Now, I don’t trust my cheap calipers on something this small…but that 8 at the top of #4 measures as 0.025mm wide - which is just about 10mil. So I’m masking things here that are quite a bit smaller than the 10mil traces kicad is configured to generate.
I think it looks like one layer of vellum with an exposure in the 1:30-2:00 will give me a successful mask for a high quality modern board layout.
For the Yusynth layouts…it should be a piece of cake.
So…I think I’m going to make a few final tweaks to mine…print it out once more. And give it a go again now that I have these exposure tests to go by!
