My build progress
it will be released, quite happy with it. the transformer should be available in 11x and 2xx versions so suitable for most countries.
May just post the files up on one of my websites, GIT is beyond my interest level ( I am sure I can manage technically but just can’t be arsed with it at present )
Where are you… I have some spare PCB that would not cost a lot to send. the bigest cost is the transformer, everything else is cheap.
The transformer is the Myrra 44440 for 220v applications, they have a 115v version of the same dimension.
Rob,
New York.
I had also been eyeing off this PCB for a rat. Noting this one is configured to switch between different diodes to allow for different distortions.
Before buying anything from Synthrotek, google “synthrotek rape joke”.
Soo, I thinking of building this on stripboard now… P:
Welp. That google search is enlightening. Im happy I haven’t spend anything on that site.
@heckseven
I found a lot of stripboard layouts for the Proco rat distortion so it won’t be a problem to build it when I have all the parts at home :slight_smile: juchey
WOW…seriously? It appears someone skipped sensitivity training. Thanks for the heads up!
Starting to actually play around more now that I a reasonable set of modules. The Midi-CV is a Key one In my opinion.
I think the VCO is well out of tune, I have not even touched the tuning side…
Going to have to start taking photos when I find a cool setting… And learning some music theory.
I got approval from Lorre-Mill to go ahead with my PCB designs of the Phase Matching Filter -
Here are the renders I submitted to him.
Added Thonkiconns up top for the I/O and have since added an LED driver to the output that will shine through the semi transparent Panel. :slight_smile:
Panels for two sets of OR wired jacks for mixing 3 or 4 gate signals as described on doepfer diy page.
One down, one to go.
A really simple passive circuit you can wire directly onto the panel.
I added the switches to allow muting of two of the three inputs.
It works a treat.
Both OR combiners complete. Good building day.
No2 was a bit neater round the back though.
Link to Doepfer diy page: http://www.doepfer.de/DIY/a100_diy.htm
I’m a lazy dog! Three Oscillators, the housing, the power supply, a modded monotron delay are ready to use but then stopped by corona… I swear to get better! :pray:
Working on one of the more difficult paper circuits…
Deerhorn Spyrallius.
There is only 1 known DIY’er who has completed a functional Spyrallius (outside of a Workshop where Peter is there to help… lol) so I figure this will be a challenge.
There is zero information on this project available…
I figure why not…
The PCB however is freaking huge. lol.
Wow, Godspeed! I really hope you manage because that is gorgeous!
Teaser no. 4
Vocoder?
Post must be at least 20 characters
Fun trick. Add <span></span> to the end of a short reply. It counts as 20 characters, but doesn’t render anything. For example, here are ten of those in a row:
