Thank you! Trying to think of a power supply idea for my next case but haven’t thought of anything great recently. I’m sure I’ll think of something super dumb ![]()
Id be tempted to steal it, but space is limited for me, my cases are only 60cm HP.
im finding it hard to decide on if i should just go basic and check a switch on the back of my cases XD
I’ve got a switch on the back of each case also ![]()
More cramming things into 2HP. Both from Hagiwo. The 4040 clock divider and simple Quantizer. The worst part is now I am going to have to do more rearranging of my Port-A-Synth modules.
Are the 4 boards in the top 2 pictures supported in some way or are the soldering joints enough?
It’s just solder joints. I used cut off resistor legs to attach things together, so there is some extra support beyond the electrical connections. It makes for surprisingly rigid attachments.
My biggest project so far is finally done and working.
It sounds really good (I’ll make a proper sound demo soon) and it is so much fun to play with.
Quad North Coast Synthesis MSK-006 Discrete Exponential VCA ported to the Kosmo format!
No chips! All transistors!!
Faceplate designed with my own software, Synth Printer
I have a more detailed build thread on my personal blog thing:
(Made this post in the wrong thread lol, it’s confusing how discourse lets you edit a draft while on the page of another thread)
I realised that my keyboard-based patches always included:
1: patch cable from MIDI module’s 1V/OCT output to a separate GLIDE module,
2: patch cables to a SUMMING AMP to add the MIDI module’s BEND output to the pitch, and
3: a passive multiple module to distribute the pitch CV to each VCO.
So here is a 4HP utility module to combine three 1V/octave CV functions: glide, pitch-bend, four buffered CV outputs.
Whenever I think of a new module I wonder what to include in it. Often it starts with a basic idea and then I invariably think “but would it not be handy to include such and such to it?”. But I also do not want to build a complete synth every time I have an idea for a new module. In reality I find it difficult to draw the line. Should I build only basic modules, consider them ‘semantic minima’ and add patch cables to combine them to something bigger or should I combine some of them into one module and have modules that are somewhere between the minima and a full synth (e.g. a Moog Model 32 mounted in a rack as a module).
A lovely little utility, bravo.
Thanks @Jos.
Usually my opinion is “modular means modular” so keep functions simple and separate, mix them up as I go.
But the prototype for this one has been constantly useful since 2019 - speeds up patching, saves on cables and keeps them localized into one corner of the cabinet.
So perhaps if there’s a patch we always plug the same way, un-modularize that bit. As a module.
It’s like drum modules — you certainly can use a VCO module, a VCA module, and an envelope generator module or two to make a drum voice. But if you’re doing that all the time, it makes more sense to have that setup in a dedicated module, freeing up three or four modules for other uses.
Evolution, @analogoutput, emerging from the primordial swamps of our modular synthsizers.
Ever thought of adding an MT32-pi to the rack? It’s a Pi3+ based emulation of the Roland MT-32.
A lot of people think of it as just a pre-GM rompler but I recently learned that it can be programmed as though it were a cut down Roland D50.
You are inspiring me to make my own rack mounted gear ![]()
I remember them when they first came out, I was so excited to hear it had 32 voice polyphony, then the truth hit, it was 8 note poly, 4 partials per note. Sounded naff then and probably still sounds naff now.
Well, at least with the emulation you don’t need to put up with the noisy DAC any more
