Well, after all, there are zillions (OK, dozens) of suppliers of VCOs and filters, but if you want a flame-controlled CV source, there’s only one place to go.
LOL . and lets not forget the sausage synth .
yeah this is why I have bought this guys stuff . definitely worth supporting this genius ,
like Sam .
It is finally a real synth now. I sort of abandoned the aluminum case for this synth, because I needed a bigger PSU. The Kosmo case turned out great, and just putting some tiny jacks that are normaled to the basic ins and outs on there makes it super versitile.
I have four of the Barton Analogue Drum Modules here. Great modules. I have modified them to Kosmo format.
Yes Barton are a great creative guy !
I already like a lot this module ![]()
For me it is part of the series of texture modules, such as Wave Folder, Timbre, Wave shaper …
I’ve not yet making a vid with it because i can’t test my new modules for the moment
Here’s the Barton MULTI PWM demo :
Sensible builders work on one module at the time…
I’m not one of them.
Working on a BMC percussion section, with 2x analog drum, 2x fm drum, 2x decaying noise. I will also add one of his dual logic modules, which I want to mod for CV-addressable gate types.
Today an Active Real Ring Modulator (from Ken Stone)
after being in a box, then a passive module, then with opamp add test, this ring modulator may finally become a real module with this circuit
All these posts with people building modules!!! I am waiting for panels and pcb’s to arrive from England. Australian Post is slower than ever.
Excited to see and hear this one!
Yes i too can’t wait to listen to it
even if i allready know how it sound
On 10cm I still had a little room, I added another mini circuit to my Utility module : a little Glide with a switch to select a different cap
and with the magic hot glue
2 positivizers, 2 Attenuverters and 1 Glide
I’ve started working on my Minibrute this morning - only got a couple points soldered in before work, but it’s a start.
Basically going to be adding in some patch points - mostly outputs - to interface with my modular rig. Still going through the list and deciding what I want, but starting out with the VCO waveforms and envelope outs, as I know I’ll want those.
I need to build a buffer board which I’ll mount with standoffs at the bottom left here (removing the current screws, adding standoffs then replacing with longer screws), but was having a hell of a time cutting down my stripboard to size. The ones I bought locally are significantly thicker than the Tayda ones and they seem to require a bit of work to cut. Plus I was trying to be quiet as the kid was sleeping.
After opening up the synth and taking a look at the board, I’m feeling much better about my soldering skills. This thing is way messier than I was expecting.
Today i’m working on the Balter (Gate delay from NLC)
and for the cap it is written that in the BOM :
1μF x 2 0805 OR 1206 25V rating or higher
i searched and it seems to be a smd ref for a ceramic one
but can i use some electro cap for this ? (like in a glide circuit)
why ?
here’s the schem
I don’t see why not. Seems to me you could use any through hole, electrolytic or MCC or tantalum. Easy enough to breadboard if you’re not sure.
thanks
…more ch…
What’s with the Vaseline?
Soft-Touch Knobs have pretty tight tolerances on their D-Shaft Knobs - just to ease the knobs onto the pot shaft
