I use this schem for 2 CD4017
with this for And gate with diodes
Small feet’s case (… behind, my Fuby that I started to strip)
the switch and the hook for the mic
A little piece of velcro for the cable
with the mic (yeah! zebra 3 zebra 3
some power
light power !
No, his French cousin
Franck?ㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤㅤ
I never knew his name, I adopted him.
But in any case he left for asylum.
After trying to replace the crystal with an LTC1799, he was in perpetual glitch until he couldn’t speak at all.
I see he is still alive because he is moving but the situation is critical.
I skalped it to make a kind of Frank Einstein taxidermy, and put his fur on another body.
The illusion will be there, but it won’t bring my … let’s call Franck now.
Is now my favourite Einstein.
Had a productive lunch break today:
Just need to make up an IDC cable with enough connecters, build the second VCO - solder the fixed up sub-osc, wait for the rev of my Nucleo ADSR to show up and build that - and finally will have to get the filter design up on a breadboard and eventually onto a PCB.
Cheers,
Jared
It took me quite a while to find the problem. It was difficult to see (even with a magnifying glass) and also difficult to make a picture off. I found a hair thin tear in the vertical copper lane which left the center horizontal voltage float in stead of at 0V.
I check all my solder point with a magnifying glass, but here it was almost invisible.
Good eyes Sherlock Holmes
I found it measuring voltages on various spots on the copper strip, then I found a voltage jump and saw a barely discernible tear and put some solder on it. Problem solved.
Today I installed the new VCO in the case and I planned to make a video for my site, but after calibrating it I started patching a few modules, and in fact I spent two or three hours to enjoy with the sounds
… maybe my video tomorrow
looking good ! …
I have always worried about conditioning digital outputs from an arduino into CV. Are you using a DAC, are you needing to condition the current with an opamp? Im clueless about that stuff.
That sounds soooooo familiar to me! ![]()
Just “test” briefly how it sounds …
Yeah, this uses a DAC. The pitch CV is scaled to a larger range with a op amp, the velocity, pitch bend, and mod wheel aren’t scaled and maybe could go direct to output but at least for now they have op amp buffers.
Hagiwo also did one recently ![]()
Thank you.
Arduino’s midi library is very useful. The most difficult process for me was drilling 15mm hole for MIDI connectors.
