Hey thanks, that’s really inspiring and I like the chords - gives some ideas of where it can be taken. I’ll see what floaty PWM pulses I can make.
On the EQ front I was trying to suppress some of that HF noise with the 3-band EQ on my mixer, but I think I just lopped off a lot of the high-end. A more surgical notch in the DAW as you suggest might be the way to go. (TODO: Find root cause of noise…). I think I also need to try and separate the bass and the arps a bit, it sounds a bit muddled to me.
I think the “drop” was me just deciding to cut the drums for a bar, but I bring them back too timidly and the rest of the track isn’t hitting back with enough. Nixing the bass at that moment too is a good idea.
Thanks for your counsel.
Tuning them is one thing. Are you also playing them in the same key?
Unless I messed up and accidentally transposed some of the midi tracks, they should be in key. I’ll double check. It might also be that I tuned them without any FM, and then introduced a little bit with some knob twisting as the track went along - need to look at the patch again (if it still exists)!
yes the bass line seems to be too hight in tune than arpegio
I always hesitate to tell the musician to “keep things in key” because that may not be their intent.
However, if it was not intentional and you want to calibrate, i recommend tuning at the A not above middle C (440 Hertz). Then, check A’s at other octaves and see if it drifts out of tune.
If this is an analog osc, its going to drift, and you just have to find a good average that give you the most accurate range that you play in.
Nice reverb :wink: !!!
Another Sunday sesh:
crankit
Was just messing around a bit with the rotate function of my clock divider with a sequencer. It creates somewhat coherent melodies which virtually never repeat:
I havent made music in like… 6 years =/ I was getting half decent too.
I need to get back to pushing the buttons and clicking the things =)
This is my reworking of Supercommuter - We’re Watching You.
Original for posterity and comparison.
A few of original workings im happy with.
Little Roolz-5 session.
I made something again :slight_smile:
It’s the gameboy for chords (into ms20 filter, controlled by lfo), 1222 osc into another ms20 filter into tube distortion for bass and then the braids into transistor ladder filter for melody. Drums are drumbrute impact. All controlled by beatstep pro.
I like it! Is that on the synth?
Its a soundfont with samples of various waveforms and PCM data captured from a NES. The soundfont is called 8BitSF, and made by The Eighth Bit.
You can find it here:
https://musical-artifacts.com/artifacts/23
Yo that’s sick! Well done.
