First one built! Kross works… if I press the pot in really hard. Does anybody know what could cause that? I redid the soldering points, no difference… bad pot?
Here, LFO causing crossove between a kick drum and a high pitched drone.
Yes, probably. If the solder joints are fine it must be a mechanical issue.
You can sometimes open them and carefully bend the wiper spring a bit, if it’s worth the time
Maybe open the pot up and check the wiper is touching the resistive track? Bend it a bit with pliers.
edit: @konthaar043 got there first!
I can definitely vouch and say the Distortion works great.
Same schematic? With or without the input level reduction?
Just referring to Christians Euro RAT -
I didn’t build it
He sent it pre-built
More pics of the Euro Rat over in Funque Mod Eurorack Modules
Demo a drum sequence? I have 4 Rat pedals, the 88 being my favorite. I’d love to see this come to Kosmo format. Thanks for posting I love Rats!
Quick and dirty demo of a simple drum loop going through. First dry, then exploring the range.
That sounds amazing
Yeah I bet isolating the kick drum and running it into the Rat would be sweet. Thanks Christian that was great.
Someone turn this into a Kosmo please. I’d love to hear some sounds from your Klon build.
That’s awesome!……………
This one really could be 2.5cm, though
Yeaahh, you know what I’ve decided that 5cm is the sweet spot for me now that I’ve built in a few different sizes, especially for effects. Fun to build, fun to play, big enough for some graphics. But this one might have to wait unless people really want it, as I’ve promised myself no more making modules until I actually make some tunes with what I’ve got…
What!? No make some I’ll buy 2!
I’ve been thinking about a Kosmo version too, but I got other stuff to take on first…
So you’re saying you’d make it dual?
The collective noun for rats is “a mischief” apparently…
Fill a case with various versions, add the patch cables and you’ll have a Rat king!
