If your good with code I bet you get @analogoutput’s DAC to do the same thing
With CVs, 4 in to 1 out, yes, I think you could. Can only do two CV outs, though, and it wouldn’t work well for audio.
Ahhh Sweat, I too thought the scripts were utter garbage… Only just about passable.
CTorp,
Is this redesign in the works?
Would be a quick fix, but I still have 5 pcbs and ICs for the max313 version so honestly I’m not in a big hurry to make the change. I will make the files available if you want to make the tweaks, would just involve re wiring that socket because the alternative chip has a different pinout.
CTorp,
I bet I could make it so you have 4 or less PCBs and ICs for the MAX313 version.
Just taking a look at this PCB now, can I suggest adding labeling to indicate which way the power cable connects? Here’s a footprint I use if it helps https://github.com/holmesrichards/kicadfootprints/blob/master/Power_Header.kicad_mod
(Also there’s the business of the jack footprint which has the tip labeled S, so the schematic has the output going to the jack sleeve, which it doesn’t. My jack footprint: https://github.com/holmesrichards/kicadfootprints/blob/master/Jack_6.35mm_PJ_629HAN.kicad_mod .)
yes 1 pcb and panel please , very much appreciated
yu probbaly meant the Max 313 chip didnt you , I would like that and the pcb if you have that.
do you have a pcb and Max 313 chip available for me to purchase? Hope Hope, thanks
yes really want this deal pcb/panel and one MAX313 chip please , rttvfilm@earthlinknet
do you have available to sell pcb,s and the MAX313 chip , really interested and this pcb from the other places is sold out .
Haven’t heard from TCorp in a minute, hope all is well. I would like to build one of these as well!
Sorry guys been on vacation/super busy! I believe all the sets are gone for the sequential but I’ll check tonight!
If you ever did another run, I’d be interested.
I’m definitely out. I would do another run but I’d probably tweak it to work with a more common IC.
hope hope this is a nice pcb , good luck as well
when you have a new run let me know asap I really want 2 thanks
If you really want a couple fast I could set you up with the gerber files @SYNTHGUY57
okay lets try that method , thanks
