June livestream! (June 28, 2020)
Stream is here, started 2020-06-28T18:10:00Z:
Simeon Rodgers’ stream, started 2020-06-28T19:30:00Z:
2020-06-28T17:30:00Z according to the Instagram announcement.
Or if it’s 2020-06-28T18:30:00Z, we’ll find out I guess.
OK, stream started 2020-06-28T18:10:00Z :smiley:
(Or 2020-06-28T19:30:00Z. Or 2020-06-28T20:30:00Z (see below)).
https://www.instagram.com/p/CB8rwU6Fmk4/
Also, here’s Sam’s Glastonbury set from earlier today (starts at ~7:15):
(you may recognize the performance from here)
well i can’t find it, although he may have meant 7:30 BST
It is not showing up on you tube and there is nothing new on instagram. Is it going on live?
It’s 7:30 bst. Said on patreon.
Hmm. Post says 6:30 and I assumed BST but could be GMT I guess. On the other hand Simeon Rodgers’ instagram says 20:30 and if you click through it says GMT which would be 2020-06-28T20:30:00Z, but no idea if that refers to the full stream or just his guest bit…
EDIT: If you click through all the way to YouTube, it says “premieres in 90 minutes” which would be 2020-06-28T19:30:00Z. Time zones are hard :smiley:
Where did you see that? I checked all feeds I know about, including Patreon, but apparently I missed something… :upside_down_face:
Astronomers got this figured out long ago, what’s the matter with the rest of us?
Loved that one! Also, Fredrik’s posts convert timezones for me, but I’m also on mobile rn.
There we go:
i joined 15mins in… was fixing the sequencer issue…
Hey, but you said its fixed now at least!
Link to Simeon Rodgers Livestream:
Its fire yall.
Was a good stream! Yall should check him out if you like mellow jams!
Youtube:
Spotify:
Instagram:
@_simeonrodgers
