Ive found when i turn all the volumes down but keep a sequence going i can hear a slight popping noise? Its in time to the trigger pulses so is something leaking into the rest of the circuit making the audible noise? Its not great for quieter parts of songs as you can still hear the popping. Reflowed all the panels and things but im just not sure whats the cause for it
Vca will still make a make a bit of noise with no signal on the input. If you kill the envelope to your vca instead of turning down volume, you don’t get a click
It seem to be more noticeable when i have the filter right down is all, thanks for the info ![]()
this kind of stuff can travel through the ground and power rails too sometimes
how would i go about fixing that? Would i just put diodes after every module plug to make sure it doesn’t travel back into my bus board? Im getting a separate adsr for the vca soon so hopefully i can fix the annoying clicking there as it kinda sucks when you just want a little bass line going…
