Expert Sleepers (or similar) DIY alternative?
Hey guys,
I was wondering if there is an DIY alternative to Expert Sleepers modules, that is, one that connects hardware and software (like VCV Rack for example) back and forth between both. Have you guys seem someone developing this or anything like it? Even not DIY this kind of modules are rare as far my concern… which is strange as i thought this would be a trend in modular synths…
Anyway, hit me up
Have you read the name of this forum?
Jk😉
What are you trying to do, exactly? Expert Sleepers makes a lot of stuff, and VCV Rack does a tonne. Depending on what you want to do you could get away with a basic midi to CV, then some form of USB midi interface - built into a keyboard, recording interface, standalone, etc. What you’re looking for will depend on how complex you want to get.
Are you looking for something like the Electro-Smith Daisy Seed or Patch ? A.o. it can run Max code.
What i meant was a module that i can send CV and Audio from the hardware synth to the computer and vice versa, so i can intermodulate each other. The only options that i know right know is expert sleepers and MOTU interfaces. I don’t understand really well what it takes to make something like that DIY, so maybe Daisy Seed could be an alternative if I have to design the circuit around it :smiley:
FLStudio has the ability to send control voltage from the correct type of audio interface capable of operating in dc decoupled mode.
I would exercise care when doing this since you might damage things if you aren’t careful.
https://www.image-line.com/fl-studio-learning/fl-studio-online-manual/html/plugins/Fruity%20Voltage%20Controller.htm
