I found an Arduino based Euclidean Rhythm Generator today and figured I would have a go a building it soon.
It was posted on Github by katspaugh
I made a Stripboard Layout for it with 2 different LED boards that are interchangeable.
Main Board -
LED Boards -
Boards attached -
LED Configuration 1
LED Configuration 2
I will let everyone know how it goes… lol
(Code - )
#include <EEPROM.h>
#define BUTTON_PIN 11
#define CLOCK_PIN 12
#define OUT_PIN 13
#define INVERTED_OUT_PIN 10
#define RESET_PIN A7
#define LONG_PRESS 600
#define SHORT_PRESS 10
#define MAX_STEPS 8
int leds[] = { 5, 4, 3, 2, 7, 9, 8, 6 };
bool alt_positions = false;
int active_steps1 = 1;
int active_steps2 = 1;
int offset = 0;
int counter = -1;
int steps = MAX_STEPS;
bool positions1[MAX_STEPS] = {};
bool positions2[MAX_STEPS] = {};
bool send_tick = false;
bool clock_state = false;
bool last_clock_state = false;
bool last_button_state = false;
bool last_reset_state = false;
int button_pressed_time = 0;
int long_pressed_time = 0;
bool getPosition(uint8_t index, bool positions[MAX_STEPS]) {
int step_idx = (index + offset) % steps;
return positions[step_idx];
void checkButton() {
bool button_state = digitalRead(BUTTON_PIN) == LOW;
if (!button_state && last_button_state == button_state) return;
int now = millis();
// Save the time when the button was pressed
if (button_state && !last_button_state) {
button_pressed_time = now;
long_pressed_time = now;
last_button_state = button_state;
int press_time = now - button_pressed_time;
// On long press
if (button_state && press_time >= LONG_PRESS) {
if (now - long_pressed_time >= LONG_PRESS) {
//offset += 1;
//if (offset >= steps) offset = 0;
alt_positions = !alt_positions;
setActiveLeds();
return;
// On button up after a short press
if (!button_state && press_time >= SHORT_PRESS && press_time < LONG_PRESS) {
if (alt_positions) {
active_steps2 += 1;
if (active_steps2 > steps) active_steps2 = 1;
setPositions(active_steps2, positions2);
EEPROM.write(1, active_steps2);
} else {
active_steps1 += 1;
if (active_steps1 > steps) active_steps1 = 1;
setPositions(active_steps1, positions1);
EEPROM.write(0, active_steps1);
setActiveLeds();
return;
void checkReset() {
bool reset = analogRead(RESET_PIN) > 500;
if (reset == last_reset_state) return;
last_reset_state = reset;
if (reset) counter = 0;
void setPositions(int active_steps, bool positions[MAX_STEPS]) {
for (int i = 0; i < steps; i++) {
positions[i] = false;
if (active_steps == 1 || steps - active_steps <= 1) {
for (int i = 0; i < active_steps; i++) {
positions[i] = true;
return;
int remainder = active_steps;
int quotient = 0;
int skip = 0;
while (remainder > 0) {
quotient = floor(steps / remainder);
int rem = steps % remainder;
if (rem) quotient += 1;
if ((i + 1) % quotient == 0) {
positions[(i + skip) % steps] = true;
skip += 1;
remainder -= floor(steps / quotient);
void setLed(int index, bool active) {
int pin = leds[index];
digitalWrite(pin, active ? HIGH : LOW);
void setActiveLeds() {
setLed(i, getPosition(i, alt_positions ? positions2 : positions1));
void onClockOn() {
counter += 1;
if (counter >= steps) counter = 0;
bool is_active1 = getPosition(counter, positions1);
digitalWrite(OUT_PIN, is_active1);
bool is_active2 = getPosition(counter, positions2);
digitalWrite(INVERTED_OUT_PIN, is_active2);
setLed(counter, alt_positions ? !is_active2 : !is_active1);
void onClockOff() {
digitalWrite(OUT_PIN, LOW);
digitalWrite(INVERTED_OUT_PIN, LOW);
setActiveLeds();
void pciSetup(byte pin) {
*digitalPinToPCMSK(pin) |= bit (digitalPinToPCMSKbit(pin)); // enable pin
PCIFR |= bit (digitalPinToPCICRbit(pin)); // clear any outstanding interrupt
PCICR |= bit (digitalPinToPCICRbit(pin)); // enable interrupt for the group
ISR(PCINT0_vect) {
send_tick = true;
void setup() {
int pin = leds[i];
pinMode(pin, OUTPUT);
pinMode(CLOCK_PIN, INPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(OUT_PIN, OUTPUT);
pinMode(INVERTED_OUT_PIN, OUTPUT);
pciSetup(CLOCK_PIN);
active_steps1 = EEPROM.read(0);
active_steps2 = EEPROM.read(1);
setActiveLeds();
void loop() {
checkButton();
checkReset();
if (!send_tick) return;
send_tick = false;
clock_state = digitalRead(CLOCK_PIN);
if (clock_state == last_clock_state) return;
last_clock_state = clock_state;
clock_state ? onClockOn() : onClockOff();
