I don’t have the final front panel yet, but this module seems to be working:
It’s a multimode VCF based on a (partial) design by Electric Druid. I made a number of modifications but the basic design is not really changed.
It uses pole mixing to achieve different filter responses. The Shape rotary switch allows selection of two different low pass, two high pass, two band pass, and two notch filter shapes. The latter two can be altered by changing resistors on the PCB; enough footprints are provided to get just about any possible filter shape. In addition there’s an expansion header potentially allowing use of a daughterboard or expansion module for additional filter shapes or other features (though this has not been tested yet).
The design is based around the Alfa AS3320 filter chip.
Schematics, layout, Gerbers, documentation, and a Python script to generate Bode plots for different pole mixes may be found at:
Ohhh, interested to see the resonance control, will look at lunch time
I built the pole mixing filter from the electric druid website about 3 years ago, it wasn’t very successful and I questioned Tom regarding some of the values used. Needless to say I abandoned it and found a better version I think by Yusynth that worked perfectly well. I built 6 of them for my wavetable synth.
So I’m glad you built this and fixed it up so it’s usable. I’m going back through some of my early stuff and realizing how little I actually knew then and now.
Wow, I’ve been looking for a home for my AS3320 forever, and looks like my procrastination has paid off!
I have now redesigned my main resonance input, thanks.
I am following the ELKA design primarily, the stage 3 block in the design has a 820K where as all the other stages are 82k, and all other designs including yours has uniform values for the stages…
Typo??
Thanks, proves I am not totally stupid and following the diagram blind :)…
Every time I come back to this it’s been over 6 months and have to remember what’s what…
On yours you invert with U3C, then had U3D to restore the phase, but then you have U2B at the end, does this not invert it back out of phase?
Hmm, yes, looks that way. Not sure what I was thinking. Oh well.
OMG, I must be getting somewhere in this whole electronics malarky.
That’s another one I tried and failed at. It seems filters are a bit hit and miss for me.
I put the fabbed panel and knobs on:
Extra boards and panels are for sale on Tindie:
is it performing as expected?
