DIY Power Supply Thread - Questions and Help
Thought I’d give an update on this, it’s been a while.
After troubleshooting almost every part of my electric installation, I seem to have found the main culprit: shoddy PCB design. It’s a pity, I really enjoy my other Frequency Central stuff, but I cannot with good faith recommend the Routemaster.
Here’s the underside of the board, on which I have traced out the ground trace. Notice the long and winded trace which connects the +12V regulator section (top left) to the ground connector. Same thing for the IDC headers, no bueno.
So I used some 22AWG wire to create some shorter ground connections. And sure enough, the supply rails went from looking like this:
To looking like this:
The supply ripple decreased from 30mV to 6mV. This raises the next question, what is an acceptable ripple level? 6mV is an improvement, but it’s still three times more than the 2mV my FC microbus gave me. At least it isn’t audible on a DC output anymore…
Well. That’s disconcerting.
Still have problems with yours?
Try bridging the gap between the regulator sections with a piece of wire, that did the trick for me.
I am having some issues, but I don’t think it’s related to this. I have a bit more testing to try myself.
Wow, that’s nuts. Even if for some reason they didn’t want to use a ground plane (is there a reason?) they could easily have done a much more direct connection on the top side.
yeah I understand very little of this board design. Sigh, I regret not designing my own, this cost me like 3 weeks
I have a question about Power Supply as I’m running out of “juice” with my current one. I’m looking into buying 2 or 3 Excalibus: Excalibus DIY Kit
As each one has 1,25A for each rail I would have a need for 3,75A. From what I’ve gathered from other threads I could hook up 2 or even 3 of those Excalibus in parallel (I’ve learned that that’s important :grin:)
If I get this power supply: Power Supply 4A Switching Brick
Which has 4A, 60Watt - this should be well enough for 3 Excalibus, right?
Just want to make sure before I order :sweat_smile:
Thank you for your help!
1 Excalibus kit = 110 euros !! :grimacing:
= 330 for 3, it’s for me the price of one complet case (power supply + wall wart + all the modules)
Frequency Central will be maybe a better alternative i think
no ?
That’s a good point, but I have a Frequency Central Routemaster at the moment but it only has 500mA per rail.
And my case is 1m wide and has 5 rows now :nerd_face: :grimacing:
So I was looking for something with more connectors and more power output. Because I really want to switch on at least the lower part (3 rows) of my case with one plug / button.
If you have any other alternatives I’m very happy to check those out though!
The correct way of connecting multiple PSUs together is to tie together all grounds and the protective earth. However, you should not connect the positive or negative rails of each supply together. They will have small differences in their supply voltages, which will lead to the PSUs back-driving eachother and damage.
like described here, right?
Jep. Inputs are connected, grounds are connected, outputs are not. Cheers,
So, can I do this with that power supply? :sweat_smile:
Or is the 60W too little for 3 (or even 2) Excalibus
Excalibus is rated for up to 1.25 A on each 12 V rail (plus 350 mA on 5 V if you use that). So up to 2.50 A or 2.85 A each. Leaving out the 5 V that’s 30 W each, or 90 W for three Excalibuses.
That’s maximum output power. Of course you would need more than that on the input.
Befaco says (for each) “Input: 9 – 18v (Recommended 45W)”. So 135 W for three.
aw shit, right - each rail! Damn…
Thank you for the explanation!
Of course that doesn’t tell how much power you need — or even how many modules you have (Eurorack? Kosmo?)
@Dud has — what is it now, 5 cases? 6? With 2 rows (Kosmo) each? It’s got to be a roughly similar if not larger number of modules, and he’s apparently doing fine with Frequency Central. Probably one or two per case so maybe as many as 12 of them, but they’re a lot cheaper.
If you really want one-switch turn on, in principle you could use a switched power strip. Turning on one at a time is kinder to the system, though.
Yes 2 FC per case of 80cm (for near 18/19 modules per case)
right sorry, should have given more context. It’s Kosmo only, so between 10-15 modules per row.
Two cases, one with 3, one with 2 rows. I was hoping to only have one plug per case going out of the row. But it seems like I’d be better off with one wall wart per row and a FC for every row then.
@Dud are you using the small green FC power with a passive board for hooking all those up or are you using the red Routemaster ones?
FYI: DIY Power Supply Thread - Questions and Help - #225 by TimMJN
Via @CTorp:
averaging 41 mA +12 V and, if you leave out the Safety Valve, 20 mA -12 V (32 mA if you include the Safety Valve). 15 modules in a row would work out to about 600 mA on the + 12 V rail which is at the high end of or a bit beyond the FC spec (~500mA at +/-12V), but it depends which modules of course.
