So face plate, and record player-style hinged top later but, im just cleaning and board peeping rn.
Its stereo so 2 mono heads but, only one mechanical rec switch that activates both so, maybe R-CH goes to an out instead of a head… maybe… or just add another preamp for playback or, both…
Antenna leg maybe switched out for an input?? (There is also an e leg, guessing emitter next to it)
There are two seperate cassette recorder preamp/etc ICs in there.
Just kinda wing it into a delay preamp, or like the old tube reverb units youd go through before your amp head but, maybe with an overdrive from the radio circuit, and/or if i could turn the antenas connection on the board into a a gate/cv input, (i dunno)… send/return wouldnt be hard. Usually i just use mixers anyways… itll probably end up sitting for a while. I meay just turn it into a 4track synthy/mellotron kinda thing, with all that space
