For all of you, I found cheap 0.99 cables at the action. They are stereo cables of 1.5 meter.
And cost not much,I already bought the compleet stock twice at mij local store ![]()
Those look great. If I send you .99 would you cut one open to see if the lumps are just plastic or ferrite chokes (is that the same as a balun? I’m tired). My CDO* must know!
As each line is 1.5m in length, cable management, on a Eurorack scale, may need a tray or recess at the bottom of your rig.
Using several at once could create some buzz or noise (has anyone here tried making deliberate noise by pushing coils of wire together or over a noisy socket. 's fun)
Oh and 3.5mm cables like these can make a good stand-in for a short, manageable balanced connections.
*CDO, like OCD but in correct alphabetical order
I cut one open,it contains a ferrite choke ![]()
The only thing with this cable is that it is not as flexible as a “normal” cable, but it is cheap…
Landed a bargain there! Keep us posted
