HMM Interesting..
It should be using the “Old Boot Loader 328”
Arduino Nano w/ ATmega328P
nano.menu.cpu.atmega328=ATmega328P
nano.menu.cpu.atmega328.upload.maximum_size=30720
nano.menu.cpu.atmega328.upload.maximum_data_size=2048
nano.menu.cpu.atmega328.upload.speed=115200
nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
nano.menu.cpu.atmega328.bootloader.extended_fuses=0xFD
nano.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328.hex
nano.menu.cpu.atmega328.build.mcu=atmega328p
Arduino Nano w/ ATmega328P (old bootloader)
nano.menu.cpu.atmega328old=ATmega328P (Old Bootloader)
nano.menu.cpu.atmega328old.upload.maximum_size=30720
nano.menu.cpu.atmega328old.upload.maximum_data_size=2048
nano.menu.cpu.atmega328old.upload.speed=57600
nano.menu.cpu.atmega328old.bootloader.low_fuses=0xFF
nano.menu.cpu.atmega328old.bootloader.high_fuses=0xDA
nano.menu.cpu.atmega328old.bootloader.extended_fuses=0xFD
nano.menu.cpu.atmega328old.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
nano.menu.cpu.atmega328old.build.mcu=atmega328p
Arduino Nano w/ ATmega168-16
nano.menu.cpu.atmega168-16=ATmega168p16
nano.menu.cpu.atmega168-16.upload.maximum_size=14336
nano.menu.cpu.atmega168-16.upload.maximum_data_size=1024
nano.menu.cpu.atmega168-16.upload.speed=19200
nano.menu.cpu.atmega168-16.bootloader.low_fuses=0xff
nano.menu.cpu.atmega168-16.bootloader.high_fuses=0xdd
nano.menu.cpu.atmega168-16.bootloader.extended_fuses=0xF8
nano.menu.cpu.atmega168-16.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
nano.menu.cpu.atmega168-16.build.mcu=atmega168p
nano.build.f_cpu=16000000L
Arduino Nano w/ ATmega168-8
nano.menu.cpu.atmega168-8=ATmega168p8
nano.menu.cpu.atmega168-8.upload.maximum_size=14336
nano.menu.cpu.atmega168-8.upload.maximum_data_size=1024
nano.menu.cpu.atmega168-8.upload.speed=19200
nano.menu.cpu.atmega168-8.bootloader.low_fuses=0xff
nano.menu.cpu.atmega168-8.bootloader.high_fuses=0xdd
nano.menu.cpu.atmega168-8.bootloader.extended_fuses=0xF8
##nano.menu.cpu.atmega168-8.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
nano.menu.cpu.atmega168-8.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
nano.menu.cpu.atmega168-8.build.mcu=atmega168
nano.build.f_cpu=8000000L
