Hi guys this is my first post, i was wondering if there is a way to add a sync cv to this kosmo stripboard?
i want to know if this is possible and if it is could someone please put it in stripboard layout. thank you ![]()
Welcome to the forum ![]()
yes it’s possible, i do it
you need to add this part of the schem
here’s my stripboard layout with add of several options
Thank you so much for your help I really appreciate it, I think I understand the stripboard, I’ll let you know when I work on building it! ![]()
Some here had some synchronization problem (including me), if so try this
“A note, the switch to engage the sync only works when the Dist pot is at 10, then I can adjust it but to engage the sync it must be fully, a little strange but it is enough to know”
