So I mentioned this in the mailday thread and it got some interest. Figured I’d start a new topic with a few more details.
I’ve been 3D printing a lot of my panels and have been really happy with the results I’m getting. My case is just “standard” Kosmo specs with wooden rails. But I’m really struggling with the wooden rails. I’ve got a bad wrist and screwing all those little screws into wood is killing me. Plus getting wood cut thin enough and accurately has proven tricky with my cheap table saw. And the wood I get is either all too soft or too hard and splits. Oh - and finding good wood screws in a proper size has also been frustrating…and those I have found use such a small phillips screwdriver I keep messing up the heads with the hard pine I wound up with for my center rail.
So I’ve been looking at options for some fancier rails. Aluminum extrusion is nice…but rather expensive for my taste.
I tried designing something I could 3D print with either my FDM or my MSLA printers, but the only designs I came up with were either too bulky for my taste or too small to print reliably without supports, and removing the supports on something that small is almost impossible.
Then I found this reddit thread: https://www.reddit.com/r/synthdiy/comments/jjsnds/3d_printed_eurorack_rails_that_snap_together_like/?utm_source=share&utm_medium=web2x&context=3
The design this guy came up with looks really promising. He basically took a standard aluminum extrusion and split it in half so it can then print without supports. But he also designed them in various lengths and in positive/negative versions so they snap together like lego. They still need to be bolted together…but you can stagger the various lengths to get longer rails than you can print in one go.
Intrigued I gave them a try. The one issue I ran into is that you need rather thin M3 square nuts for them. Most of the nuts on Amazon are 2.5mm thick. And these are designed for thin DIN 562 nuts which I couldn’t find on Amazon (well, I could but they didn’t have prime and were kind of expensive at $20 for 100 nuts or maybe it was 200.) So I ordered mine from McMaster, which is always a bit of a gamble since shipping is up to them - but I’ve never really been burned with unreasonable shipping prices from them. I wound up getting 200 nuts for $16 shipped and they arrived in one day.
They fit great, and the rails work perfectly:
You do need to make the case a little taller than for a “normal” Kosmo since there’s a lip on one side of these. So for a two row case you wind up with 4 extra lips and the full height for two rows is about 410mm.
The guy who shared these did release STEP files so you can modify them. You could make them work with the cheaper nuts you can get off amazon…but I got some of those and I’m not big on doing that:
Those are the “correct” DIN thin nuts on the left and the cheap Amazon nuts on the right. Not only are the Amazon nuts thicker (which would result in weaker or bulkier rails to accommodate) but they also have rounded corners so they don’t quite have as much surface area to lock in place. They aren’t bad…and if you’re on a super tight budget are definitely an option. I’m going to stick with the DIN nuts though myself.
I’ve printed this much to test with so far:
I think I’m going to go ahead and use these for my next case. Just waiting on some more black filament since I’d rather print the rails in black and I’m almost out.
How much time does it take to print these? Well, on my prusa Mk3 at 0.3mm draft settings I can print 1 pair of the 36hp rails in about 2 hours. And two sets of 36HP with 2 sets of 18HP takes me just under 7 hours. Working it out…enough rails to fill a “standard” Kosmo case would be pretty close to 48 hours of printing. Actually that would give you more than enough rails for a full Kosmo case. I haven’t tried to work out the optimal number of rails to print and instead have just focused on how many of the full plates with 108hp of rails it would take.
The rails I’ve printed so far in the photo above are about 13 hours of print time. One 7 hour print with 2 36hp sets and 2 18hp sets…and 3 2 hour tests of just one pair of 36hp each.
Oh - and for those wondering. The center rail made from 2 rails bolted together is EXTREMELY stiff and should have no problem spanning a full Kosmo sized case unsupported. It seems quite a bit stiffer than the 1/2" pine I’m currently using.
I also picked up some M3 threaded inserts: https://www.amazon.com/gp/product/B00270ZSIU?pf_rd_r=RAXR5S909RDHQH1EFMF2&pf_rd_p=edaba0ee-c2fe-4124-9f5d-b31d6b1bfbee&th=1
I figure I’ll install those in my case and then use the same screws that bolt the rails together to bolt them to the case. The center rail I’ll use the nut traps provided in the ends to bolt them in from the sides of my case.
There are side supports to create a full frame out of printed parts that the designer shared - but those are sized for eurorack (and he said he may do a 5u size) though with the step files it wouldn’t be hard to create a 200mm tall Kosmo version either.
