Some testing trial observations on my shop bench with various Tanks:
First some useful Info on tanks.
Accutronics reverb tank numbering system
The type 4 is 17" long and uses 2 long springs, each of which consists of two springs joined in the middle. Thus, Accutronics considers this model a 4-spring unit. This type was the original style selected by Leo Fender.
The type 8 is 9" long and uses 3 springs. This type is most famous for its use by Marshall™ . The type 9 is 17" long and uses 3 long springs, each of which consists of two springs joined in the middle. Analogously, Accutronics considers this unit a 6-spring device.
All Accutronics part numbers consist of 7 characters as described below.
1st character: type 4, 8, or 9
2nd character: Input impedance @ 1kHz
Type A B C D E F
4 8 ohms 150 ohms 200 ohms 250 ohms 600 ohms 1475 ohms
8-9 10 ohms 190 ohms 240 ohms 310 ohms 800 ohms 1925 ohms
3rd character: Output impedance @ 1 kHz
Type A B C
4 500 ohms 2250 ohms 10000 ohms
8-9 600 ohms 2575 ohms 12000 ohms
Next: What I found through actual plug and play
High impedance input tanks require less signal amplitude to drive them. The feedback feature tends to be almost uncontrollable with these Type E or F input tanks.
RV-1 is the tuning attenuator that can be adjusted to fit the tank but I had to set this almost all the way to minimum with the High Impedance tanks
Low impedance Input tanks respond the best with the feedback loop
A or B input tanks (low inpedance) are my clear favorites as far as sound and control of the feedback are concerned.
I can get a very clean spacious reverb or something quite strange.
Output B Type works best with this Module
I used an A Type output but heard some distortion at even low levels
9AB3—, 4BB3— are good candidates - I had to adjust RV-1 for each
the 8EB3— and 8FB3— tanks I have were too wild… I even damaged U2-A, B using these tanks
2 spring tanks or 3 spring tanks are great with this module
