Hey I recently have been looking for decent filters and have stumbled upon the MOTM-480 filter and decided I wanted to take a crack at it. Thing is it requires 15 volts and I only have a 12 volt power supply and don’t really want to get a 15 volt one. Would it still work and perform well at 12 volts or is the 15 mandatory? I will also include a link to the manual if it helps, can anyone help? https://synthtech.com/docs/MOTM-480_manual.pdf
Some 15V modules work well in 12V without any changes, but others require some value adjustments. The best would be to build it before on a breadboard to test it in 12V
