Hello,
First full module build and hitting some roadblocks.
I am not getting any lights from the screen or the LEDs and also no sound from any outputs. Is it possible to get sound without the LEDs and screen lighting up?
I damaged the pcb board when de soldering the connector that holds the bank of 8 1/4 jacks. I did a quick fix on the copper and do have continuity between the CV pin and the cv control potentiometer but wondering if that could have impacted something else?
I have worked my way through a bunch of the trouble shooting info on the site but still no joy. As this is my first module I have a few questions.
I bought a few 1W and 2W resistors when I sourced components that I used in this build, will that be causing any issues? I read online that in most cases it will not but wondering on what you guys think or have encountered.
TL072CN is reading -10.67V at pin 4 but pin 8 is reading -0.61V
TL074CN is reading -10.67V at pin 11 but pin 4 is reading -0.61V
CEM3340 is reading 0V at pin 14 which I think should be reading something!
I am not getting continuity between pin 14 on the 3340 and -12V from the power header, presume I should be though.
The Arduino is read - 0.22V at the VIN pin which should be more?
I have tried to check resistor values but when I use my multi meter the values are different to what they should be on the meter, I got the same component out of my resistor box though and tested it and it reads as it should. If I have plugged the module in will the resistor values change or something? This part really confuses me. I just plugged the module in and the values are sort of close but still not on, do the capacitors or the circuit itself effect these?
I have also swapped out the TL072 and TL074 chips for different ones but I donât have a different 3340 chip to try, could the chip be damaged? But I should still get voltage still surely when I test the actual pcb part of the board?
I am basically stuck and hoping I have missed something basic that someone on here can spot!
All help is much appreciated!!!
