I’ve recently built 4 of the 1222 modules, but unfortunately I’m finding them very difficult to use due to the tuning drifting constantly.
Here are the various issues I’ve got with them:
After playing them for just a few seconds, the tuning is often out by a semitone or more. I would play the same sequence of notes and you can hear it shift rapidly.
The general tuning seem to drift over time as well, over the course of one hour, it would gradually go up in pitch, maybe a semi tone every 5min or so up to 4 semi-tones.
I’m not sure how accurate the in-built tuner is but it can not stay stable, the leds would go from red to green to red multiple times per second. Which I’m guessing would have something to do with the overall tuning being unstable
I find that I have to re-calibrate the center note every time i use them.
I’ve changed R42 for 1k, and the problem seem to occur regardless of the waveform. All of them have the same problem too
I’m wondering if anyone has had similar issues and if they have managed to fix them?
So my wall wart is outputing 1000mA, I believe it’s the one that frequency central linked to in their build guide, I didn’t really think twice and went along with it.
Do you think trying a 2amp one would be worth a shot in my setup?
I can see the danger in forgetting to switch the lead back, my meter yells at me if I’m in the wrong mode though and is supposed to be good for 10A. Measuring the voltages does sound a lot less fiddly tho
It’s a nice meter, I wasn’t going to go name brand but I thought about how my dad still has his fluke from the 80’s (which probably cost a fortune in the day, or maybe a transmission rebuild in his case) Hopefully I won’t have to buy another haha.
I had this same problem when running a 1000mA Wall Wart - same combo with the frequency central microbus power supply.
Upped it to a 2000mA supply and all was fine.
I’ve not considered the total current draw of a ‘row’ of Kosmo units, but went on the premise that the same PSU with similar configuration on Sam’s cabinet-build instructions mean I’ll be in the right ball park.
