Stefan,
They say nobody beats the Biz. Apparently in this case the Aiz beats the Biz.
Stefan,
I have a new gremlin that showed up a couple weeks ago. After a certain amount of time, all three oscillators in my top row start wobbling (almost like a fast LFO is connected to the pitch). Have any of you experienced this?
Details:
The next time it happens I will double check the temperature of the power supplies and wall warts. I will note how long it takes to happen. I also plan to remove modules one at a time once it happens to see if one of the other modules might be the cause.
That does sound to me like it might be a power issue. With no CV plugged in, that seems the most likely source of a problem common to all three.
Have you measured the current draw of the phone module? Has anyone measured the current draw of the MidiMuso?
Itâs got to either be the power supply itself, or something causing ripples in the power supply output.
A dual trace scope on the supply lines should show this.
Swap one at a time from the top cabinet into the lower cabinet. Will help you figure out if itâs a module or the cabinet/psu
Okay. So. Itâs somehow midimuso related.
More notes:
Will shift the conversation to that thread when I know more.
Mine have been doing the same thing on and off. I just tried unplugging the MIDImuso, but it doesnât seem like it makes a difference. Whatâs happening is that the reference voltage is unstable. Hereâs a video:
EDIT: I now unplugged everything but the VCOs and theyâre behaving the same way. One more than the other.
Could it be related to this ?
Hmm, not a bad guess. Let me check that out.
Well, will you look at that:
I put in a 1K and itâs stable. I measured the resistance of the 220R I removed, but it still measures 220, so I donât know if it could be burned out. In any case, fingers crossed that the reference voltage stays stable.
Let me know please. If so, Iâll do the same thing next week.
May be worth a sticky at the top if it fixed it, or itâs own short threadâŚ
Yeah, still solid several hours later.
Cool, @Hackseven , give it a try and if it solves the problem
Did you replace the resistor on all oscillators? The Truly Scientific Test would be to just replace one and see if its behavior changes while the others donât. But this does look promising. I do think @lookmumnocomputer should update the schematic/bom with a 1k resistor.
I did replace both, but the other module was mostly stable anyway. Would just go wobbly every now and then.
Iâll try that this afternoon.
Alrighty. Science results:
I could try swapping it on the others in case the unstability bleeds to other modules somehow.
I think we probably had different problems that just happened to manifest the same. It could be that the MIDImuso draws enough power to push your power supply past the limit. What happens if you unplug several other modules but not that one?
Seems like it might be a power supply issue of some sort.
I use two FC Microbus power supplies per case connected in parallel I think. Each case has one 12V 2a AC AC wart. Perhaps I need to get a better wall wart or explor other power supplies? Ideas?
I suppose I could also separate the Microbus and have a wall wart per bus, but I was hoping to keep it to one power cord per case.
