That’s because of the design of the 3340 chip, see
and
and the 3340 datasheet.
The pulse wave in particular has a larger maximum level than some modules expect — the peak to peak difference is fairly OK, but it’s 0 to 10.5 V rather than centered on zero — so might need attenuation going into them.
There are 3340 VCO designs out there that add gain/offset stages to make all waveforms the same amplitude, and remove the DC level, so they’re all ±5 V. But the 1222 isn’t one of them.
