1221 Oscillator Expander
The page for the 1221 oscillator expander module is live:
yes thanks and we are sowaiitng for the price in store section,want 2 at least
2 Osc Expander would be apply to a likely 3 Performance VCO mixed / 3 Kosmo synth voice mixed scheme.
Here they come
Hopefully the VCOs stay in stock!
Need to figure out how many things i need to order this time around…
a whole synth voice im trying to get finished and out before chrisrtmas, it also works pretty well with this too!
  • almost done
  • I got no action on the lfo… debugging is fun :slight_smile:
  • next stop VCOs. I currently ony have two working ones, their friends are stuck in my backlog…
AND there is an update to the BOM:
13 100k resistors are needed, my version of the BOM said 12
A synth DIYer who doesn’t have a couple hundred spare 100k resistors lying around!? :laughing:
just to prevent confusion…
I started with the 100Ks because they are the (low profile) component with the highest count. when inserting the 100Rs I stumbled upon one unpopulated instance of 100K. I started doublechecking and counting… I found that I made no mistake and added one more 100K. If i had found the unpopulated 100K instance later with more resistors already soldered in the hunt for the error would have been considerably longer. especialy for those of is who can’t read resistor-stripe-codes…
(edit: a few less typos)
I finally got around building this, seems to work, but LFO led looks weird. I have bi-color led there, it seems like the both colors are on all the time. Or at least it stays on the same brightness constantly. LFO itself seems to work, so I need to check what’s up with the led.
And I forgot how hot and one-sided the output from the 1222’s is, putting them directly to the funky filter overdrives it too much, and using my own VCA distorts it quite easily too. I need to tame the signal levels a bit, and maybe add something to sum constant voltage there to counter the dc-bias.
Well, seems that the lfo isn’t really low frequency oscillating, but problem is that the frequency is very high and that’s causing the problems. All components seem to be right ones, so this debugging isn’t progressing…
What should actually be the frequency range of the lfo?
RC = 56k x 100 nF = 5.6 ms implying ~ 28 Hz. Simulation gives about 1 Hz at one end of the pot, ~23 Hz in the middle, ~100 Hz at the other end.
Ahh, now it works. I had 100k instead of 100 ohm for R7.
RV5 in the schematic is a 20k trim potmeter. I only have 10k and 100k trim potmeters. For those who already built this module, how much K-Ohm do you think was needed to make it tuned to 1V/Oct? Do you think a 10k or a 100k trim potmeter could be used?
(Ofcourse I could add one 20k trim potmeter to my next parts order, but that will take some time, and I would love to finish this module during this weekend… :smiley: )
Stefan
I think (=uneducated guess) the resolution (number of thurns per ohm) on a 100k pot is not fine enough. i replaced a 10k pot with a 20k (on a 1145 LFO) and it got realy fiddly calibrating it. with 20k vs. 100k the difference is even bigger…
If the pot has about 25 turns for 0 to 100k then 1 turn roughly translates to ab out 4 ohm. compared to 0.8 per turn on a 20k
i might be wrong… in that case correct me!
Thanks! Your reasoning matches mine, so I will give the 10k trimpot a try and see whether that will suffice. If not, I can always replace it with a 20k trimpot in the future.
Stefan
can someone who has used the sync ports on the back of this and the performance VCO explain to me exactly what the sync does? Especially when it comes to multiples. What would be the use case for connecting 3 VCOs to this via the back panel sync cable?
Update: turns out the 1V/Oct bipolar LED was working after all. It was the infamous ‘it needs to be triggered by a higher voltage’ issue. :smile:
I prreviously only tested it with low voltage sources, such as a CV sequencer with less than 2,5V, which was not enough to trigger the LED.
After testing it with e.g. a square wave 9V LGO in the CV input, the bipolar LED lights up beautifully!
[Solved:
During this Christmas holiday, I finally have the time and willingness to work on some half finished modules, one of these being the 1221 Oscillator Expander. It seems as though I am nearly there for this module, except for one minor thing.
Up to now, the 1V/Oct LED has not lighted up. I had stuff plugged in the 1V/Oct input, CV input, and PWM input, but the LED does nothing. I have used a bipolar LED, and I have tested by placing a normal LED in both directions at the legs of the bipolar LED, but the normal LED also does not light up, so I do not think it is an issue of reversed LEDs.
Therefore, my question is: When should the 1V/Oct LED light up?
Thanks in advance, any ideas might help me troubleshoot!]
so i just built this, just waiting for a few missing resistors and the LM13700 to arrive. what do you connect the output jack to? is it the output of the LFO? otherwise the LFO can just modulate pitch, is that right?
The output is the mix of all modulations the module can produce (LFO, slide) and process (V/oct, CV modulation). The output can be used for the (modulated) 1V/Oct input of a VCO, or as a (complex) modulation source for whatever you want.
You can also have it linked with a cable on the back to Sam’s VCO modules, but I haven’t tested this out.
It took me a while to figure the module out, but I absolutely love it! I have not connected it via a cable with VCOs, as I also want to use it as a standalone modulation source. I am really considering buying a second one!
