Is there an equivalent to the BZX55C2V0 on Tayda?
Itâs a 2.0 V zener, which Tayda doesnât have. No time to stare at the schematics right now, but last time I did I seem to have convinced myself that the exact voltage isnât that important:
and Tayda has a 2.4 V zener:
Thank you, Mister Wizard!
possibly not the right thread to check, but its more of a âpre-emptiveâ dumbassery check =)
wondering if i can use the latter instead of the recommended Mouser 1/4 Jack for the 1183 Quad VCA, the footprints seem very similar. Perhaps a slight bending of the legs will be needed but thought i should check anyways =)
Quad VCA 1183 recommended 1/4 Jack:
Grafik1 (mouser.co.uk)
1/4 Jack from Thonk (where im getting the rest of my stuff)
TYIA for the help. =D
That should work fine.
Cheers AO =) i should have read the bit that says:
âThese are compatible with footprints for the Switchcraft 112A and the Neutrik NYS234â before i posted really ;D
haha!!
One more quick question before i jump into making this one. Ive got all my bits together and just looking at the PCB the 470k have a rectangle around themâŚ
is this one that needs to be precise or ânear enoughâ or is it a part that can be omitted?
Ive got a few already in my âready to buildâ box but want to be sure first.
I was just wondering the same thing. Did you ever get an answer to this question?
Maybe ping @lookmumnocomputer for the answer
I used whatever I had in my stash, seems fineâŚ
near enough. iii could even be 220k probably. but 470k is a nice common value. it is the knob which connects to the level knob on the front panel. 220k would just be a bit more sensitive. but in honesty I donât think youâd notice any difference
Donât know what the box around the footprint signifies. Itâs just an input resistor to the summing amp.
R4, R6, and R8 are the same. Ideally you wouldnât substitute for one without substituting for all. Ideally.
If you have lots of 220k you could double them up in series. 440k would certainly be close enough. Or if you went nuts once and bought a ton of 1M you could use pairs of them in parallel.
