Been there, done that, never did get the T-shirt!
quick one as I can’t be ARSD to look…(Have I invented a Geek Synth Term) is the MOM to the top of the PCB and Latch to the bottom or the other way round.
Switches here
Doesn’t matter, really – both directions go to the same input (gate/trigger) so it’s up to you what you prefer.
Ahh Perfect…
Will have that finishe tomorrow then, bar the knobs.
That’s because you didn’t click “Submit my order.” (Yes, Jason, that was the joke…)
Never followed up in this one, but @Dud just posted a drawing:
Hello everyone
Run into a problem. I only have negative output in my mini ADSR module. I checked all the connections and also replaced R12 and R15. Didn’t seem to help.
Would be grateful to hear any advice.
hello sos breakdown service I listen, I will give you a specialist as soon as it is available, good day to you
(joke)
As in “only the negative output is working” or “all outputs are negative”? Do you have signal at pin 7? Are pins 5, 6, and 7 properly soldered, and properly seated in the socket (if in doubt, check continuity from IC pin to solder joint).
Should have been more specific. Only negative output is working, all three positive outputs are not. I checked positive pins with oscilloscope and no signal, just flat line. Reheated the solder on 5,6,7.
I think checking the continuity from the IC socket will be my next step.
Thanks for your advice anyway
What the positive outputs have in common, but not the negative, are R12, R15, and pins 5, 6, and 7 on the TL072. Try focusing on them.
Hello,
i buit the circuit following the schematic but i have an output envelope only if i touch the metal d-shaft of the potentiometers with my fingers.
What could be the cause of this?
I share all GND of the potentiometers and i tried adding the 100nf caps.
Thank you.
P.S. i didn’t use the opamp and i have only 1 out at the moment.
Sounds like a grounding issue… have you connected the shared ground from the potentiometers to the ground on your stripboard?
I checked again and i replaced a potentiometer… aaaand i found a pin of the socket chip was not soldered correctly. It works now.
Thank you.
It sucks to have to comb through everything sometimes, but usually it ends up being one of these things. I am glad you have a working module now!
I was looking at the LED driver for the output and input:
In the kassutronics asr he uses a similar setup, but with different values:
For the LED okai, different LEDs, different preferences for brightness, but the one before the transistor? Also: Why does Caspar split the resistors in the “LED path” into two before and after Q1?
The difference is the emitter voltage, I think. In the first design, the emitter will never go above the LED’s forward voltage (the resistor takes the rest of the 12 V, minus a tiny drop across the transistor), in the latter part of the 12 V will be dropped across the 2k2 resistor. Since a transistor works as an amplifier until the base voltage exceeds the emitter voltage with about 0.6 V, at which point it turns into a switch, the second design turns fully on (saturates) a bit later.
EDIT: Well, ok, it starts conducting earlier as well, since the emitter voltage will increase linearly as the current through the transistor increases, unlike for the very non-linear LED. It’s basically using the transistor as an amplifier, instead of using it as a switch (it’ll still saturate at higher voltages, since there’s no biasing on the base side of things, but you get a larger usable range).
So, per the dumbass thread:
I managed to clean out the holes enough to put the chips in. Plugged it in and immediately unplugged. Thankfully, the first thing i test whenever there is a sketch build is: “does the op-amp get hot”? I dont plug in anything else until i rule that out. Thankfully, since after plugging this thing in, it was scorchy. Afterwards, i test continuity and everything seems to be connected per the schematic. Connectivity to ground, +12, -12 are where i expect them to be. I think i might just have to call this a loss. At first i thought i must have put the cursed opamp in backwards but it was not the case.
Ill have to keep lookin’ and stuff, but given that i kinda botched the chip soldering by originally doing it on the wrong side and having to de-solder etc, i think its time to call it. ![]()
Don’t give up! Surely it can be salvaged.
