1008 MIDI to Trigger
Ill try soldering 100nf then between pins 5 and 8 should be easy to do on the reverse of the board.
Woo Hoo
Added the cap no difference, postman calls and some 137s arrive. Popped one in and bingo all working.
Just waiting for the hex trigger to arrive to finish off :slight_smile: very happy
Matt
And I used a 74C14N and that worked fine driving the midi thru and LED circuit.
The two are quite different internally:
Fairchild datasheets quote electrical characteristics with a load resistor of 350 Ī© for the 6N137 versus 1.9k for the 6N136. In this module a 10k load resistor is specified! I’ve seen values of 1k to 10k with the 6N137 in MIDI circuits I’ve found online, I don’t know why they use such high values. (I went with 3.9k in my MIDI to CV, somewhat cargo cultishly, but at least that’s within the 350 Ī© to 4k range shown in the datasheet plots.)
With the stated loads, the 6N136 has propagation delay times of 300 to 450 ns, compared to 40 ns for 6N137. Low-to-high time for the latter is much longer with a 4k load and I can only guess it might be around 200 ns with 10k, while high-to-low time is insensitive to RL at least up through 4k. Both times get longer with larger RL for the 6N136 so might be up around 600 to 700 ns at 10k.
I’ve read the 6N136 is actually too slow for the MIDI spec. But you’re probably not pushing the MIDI speed limits here, and with a 10k load the 6N137 isn’t a lot faster. (No, it’s the 6N138 that’s too slow, with propagation delay times of 1.5 and 7 µs.) So I’m kind of surprised it works and the other doesn’t.
Hmm, I seem to have a dead short between +12 and ground. Can’t spot it as yet and think I am going to have to get a thermal camera. :frowning:
Ouch… did not realise thermal cameras were so expensive.
Well, I pulled all the IC’s and desolderd the regulator, 2n3904, electrolytics… And still a dead short, went over with a big magnifier and no joy. Started unsoldering legs of 100nf and efter 4 found one that cured the short and low and behold the 100nf was 0Ohms resistance or close enough.
Re-assembeld it and tested ebfore chips in… No short :slight_smile:
Chips in and more smokle from the 10R resistoe. chips out and then back in one by one. until I found the offending socket… Ahhh, chips oriented correctly to the socket, socket is oriented like all the others but the footprint is actualy the other way up 180 out compared to all the others.
Anyway it’s all back togheter and I have modded the code to do a ā€œlamp checkā€ on start up…
Hopefully get it tested tomorrow :slight_smile:
update as i cant post again…
So it’s all tested and working spot on. I have done some updates to the code which I will publish, mostly at the moment to do a POST so it triggers all the outputs on boot to confirm the hardware is working.
Update 13/7/23
Since I can’t post again update here
The second video of the diagnostic and test . Quality is terrible for some reason and the mic cuts out
And my slightly revised code with the lamp check.
I also saw this on the description page and was surprised as usually the hardware is different for gates/triggers and notes. Has anyone tried using it for notes?
I’ve only used mine to send trigger/gate as Rich said, though I haven’t dove into the code at all. Imagine you could use three of the outputs to drive the Plexquencer and arpeggiate across 8 notes?
Also, since I have you here, been loving your videos leading up to Defcon. Really enjoy a lot of the moments in Third Rail. Have a great set!
heck yea! appreciate that! def curious about it and will probably take a pass at seeing how it handles pitch (or doesn’t) after defcon.
I recently built this, it just works. And now I’m thinking about modding it so that it would have multi-connectors on the backside for atleast some of the outputs, so I could connect it to some drum modules behind-the-scenes. Basic drum modules don’t usually change, so it would de-spaghettify things somewhat.
Soldering stuff straight to those board-connecting-headers would be a solution, or making an extra board sandwiched between those existing boards and taking signals from there. Let’s see what happens.
I have always found it a benefit to add what I call pass-on features to component projects. A MIDI in gets a Through available (even without a socket), jacks often have a switched state available and my last design has a midi bus and merge block.
where did you find the powder blue jacks? Very stylish.
Aliexpress ….. order history indicates i have bought 200 of them!!
https://www.aliexpress.com/item/4000557177947.html?spm=a2g0o.order_list.order_list_main.10.1eba1802QKgHlA
