Does anyone here get into using old equipment to generate extra signals like oscillators from a function generator?
How do you personally patch it into your system?
I just made this passive device, similar to the Low-Gain UTIL and am curious if I should throw a resistor or something from the banana IN to the Signal out.
Would love to know if I should maybe add a pot from the banana to lower the signal?
Any suggest?
Thanks all!
When there’s any doubt - buffer it. Buffers add nothing and take nothing away but could stop your 1970’s Kenwood food mixer from frying your synth when you plug in.
You could always add a “patch-pal” type attenuator externally if the signal warrants it.
Hm, since I know my one Function generator puts out 12v, and at the moment this is mainly an Input Module, I may just use Voltage Dividers and bring one to 8v, one to 7v, and one to 6v.
Now they are buffered with Voltage Dividers.
Top Input gets divided to 8v.
Middle Input gets divided to 6v.
Bottom Input has no buffer.
Can’t really comment,
But I am a Dab hand with photoshop
