Added them!
20 characters
Added them!
20 characters
Weirdly the STLs lack some sort of data needed to scale them properly and they import into Creality’s slicer at like .25mm wide. Do you have the precise LxWxH numbers so I can manually scale it?
EDIT: I loaded it into Prusaslicer and although it also complained about the scale, it was able to convert the file to the appropriate scale.
Weird! I’ll have a look at it tomorrow, it should be in meters.
That’s what Prusaslicer complained about. It saw meters but wanted mm. CrealitySlicer had no idea what was going on. IDK. Never saw that happen before. Sort of surprised STL doesn’t have it’s own standard way of handling this
@AriaSalvatrice can you send me your dual 9v STL?
Need to make one for a white noise box.
Over the years I’ve made a few things (which are available all over the most common sites Thingiverse, Printables and maker world)
Module display.
https://makerworld.com/models/1027318
Potentiometer PCB mount.
https://makerworld.com/models/1027247
Patch cable hanger.
https://makerworld.com/models/1027301
HSW Patch cable hanger - short.
https://makerworld.com/models/1027218
HSW Patch cable hanger - long.
https://makerworld.com/models/1027201
Downloads and likes would be wonderful!
On either/any of;
https://makerworld.com/@willow2x
(Lesser maintained)
Useful stuff.
Thanks for sharing.
Bear in mind I remember nothing about the details of this model, not even in what program i made it… only guarantee is that the batteries will fit, probably, hopefully, normally.
Thanks! That’s no worries, I’ll be able to import it to blender and check things out.
Might make a couple small changes, the slight curve on the bottom looks nice but might not print well for me and I’ll add a retaining clip on the battery parts, so there’s the possibility of mounting it vertically.
Thank you again!
